Author Topic: What exactly comes with a Kmac kit, and what else would I need to buy?  (Read 1681 times)
Offline rockhawksam
  • I'm a big dirty **** Hawk
    • tanglingstars.com
I am a little confused about all of this stuff, help is appreciated and thanks!  :thumb:
Offline Pacifist
  • on hiatus
Re: What exactly comes with a Kmac kit, and what else would I need to buy?
« Reply #1 on: Sun, 27 April 2014, 21:07:19 »
kmac kit from where?
« Reply #2 on: Sun, 27 April 2014, 21:09:08 »
A brand new KMAC kit from kbdmod.co.kr or originative will include everything you need except switches, Cherry PCB-mount stabilisers, keycaps and a mini-usb cable. You just need to assemble/solder it and put keycaps on.
Offline rockhawksam
    • tanglingstars.com
« Reply #3 on: Sun, 27 April 2014, 21:29:38 »
Awesome, thanks for the help! I am under the impression that the winkeyless layout requires a 7x spacebar, where would I find stabilizers for this?
« Reply #4 on: Sun, 27 April 2014, 21:34:41 »
Yes, that's correct. The best way to get a bunch of Cherry PCB mount stabilisers including a 7unit wire is to take them from a winkeyless Cherry G80 board. Or you could try the classifieds. In total you will need :
4x : Cherry PCB mount stabilisers with 2unit wires
1x : Cherry PCB mount stabiliser with 7unit wire
Offline Pacifist
  • on hiatus
« Reply #5 on: Sun, 27 April 2014, 21:34:41 »
gon, iirc originative is sold out
« Reply #6 on: Sun, 27 April 2014, 22:01:45 »
You may also want to get some LEDs as well, though they are optional.
