Author Topic: KMAC Plate  (Read 1147 times)
Offline Blackehart
KMAC Plate
« on: Mon, 28 April 2014, 01:19:11 »
Does the KMAC plate work exclusively with the kmac case? Will other plates work?
(think adding a switch moddable plate)
Thanks,
-Blacke
Re: KMAC Plate
« Reply #1 on: Mon, 28 April 2014, 01:23:47 »
for the early KMAC and KMAC LE the plate is specific. For the KMAC 2 you can in theory use a new plate, as it allows PCB mounting for no plate, but you'll likely only be able to screw it down in a few points.
You can mod the plate pretty easily to support switch top removal as it's just aluminium.
