Author Topic: IBM Model M SDL-to-USB cables available in beige  (Read 4569 times)
« on: Wed, 30 April 2014, 11:34:41 »
- D Trump 2026-10-24
Offline sebk
Re: IBM Model M SDL-to-USB cables available in beige
« Reply #1 on: Thu, 01 May 2014, 03:02:19 »
Interesting. Almost $40 seems steep though, doesn't it?
« Reply #2 on: Thu, 01 May 2014, 06:16:12 »
It's about normal, and it includes a USB adaptor moulded into the plug.
I have one of the black cables - it lets my Model M work perfectly with my Mac - an excellent cable!
Well worth the price, even though it cost me more for one cable than did both of my Model M put together :))
« Reply #3 on: Thu, 01 May 2014, 13:24:45 »
He makes these individually by hand and had to buy the components in quantity.
A standard M cable is likely to cost you at least $15 shipped and I think that they are pretty ugly and bulky. And you still have to get an outboard USB converter, another kludge.
Offline sebk
« Reply #4 on: Thu, 01 May 2014, 15:05:15 »
I didn't consider what the cable costs by itself. It is a pretty neat solution though for then the cable does give in.
« Reply #5 on: Fri, 02 May 2014, 17:55:46 »
I was looking for them for a while, and couldn't hardly every find them for under $20
Also keep in mind how ridiculously expensive the SDL end is. It's over $5 for the plastic, and I see he has included the upper and lower metal shielding and the ferrule. $40 is a bargain considering the materials cost alone.
« Last Edit: Fri, 02 May 2014, 17:57:19 by dorkvader »
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #6 on: Fri, 02 May 2014, 23:27:44 »
Orihalcon has added a beige option for his excellent Model M replacement cables.
http://www.ebay.com/itm/BEIGE-USB-to-SDL-6-Pin-6ft-IBM-Lexmark-Unicomp-Model-M-Clicky-Keyboard-Cable-NEW-/271470078682?rd=1
Thank you so much for this, looking everywhere for an all BEIGE connector to my Model-M's  :thumb: .
Offline False_Dmitry_II
« Reply #7 on: Sat, 03 May 2014, 00:08:45 »
I get the cost, and think it's a fair price. What I don't get is why it must be USB in the first place, most of the time I just use PS/2.
Only one of my two M's even has an SDL connector, though, so I can't make much use of one.
« Reply #8 on: Sat, 03 May 2014, 08:28:58 »
No need for USB at all if you use the original SDL-to-PS/2 cable and your motherboard accepts it.
Offline HannibalChew
  • Formerly PixelScript
    • gaffworks
« Reply #9 on: Mon, 05 May 2014, 15:11:32 »
Defiantly grabbing one of these when i find myself a model M.
« Reply #10 on: Mon, 05 May 2014, 15:17:12 »
Be positive and buy the cable now!
Then you won't have to wait for the cable if you suddenly find a Model M ;)
    • gaffworks
« Reply #11 on: Mon, 05 May 2014, 15:19:23 »
Maybe i will actually, it will also force me into finding a model M asap!
« Reply #12 on: Mon, 05 May 2014, 16:01:50 »
Remember that Lexmark switched to fixed cables along about the mid-1990s.
Offline Frenir
  • HHKB Viking
« Reply #13 on: Mon, 05 May 2014, 16:05:55 »
Just purchased one these, hope to be able to use my model m soon.
