Author Topic: Keycool backlit 87 illuminated with RAINBOW KEYS ??  (Read 2209 times)
Offline da20valve
« on: Wed, 30 April 2014, 20:23:35 »
Offline Beca
  • what am i doing with my life
Re: Keycool backlit 87 illuminated with RAINBOW KEYS ??
« Reply #1 on: Wed, 30 April 2014, 20:34:59 »
what do you mean exactly? won't it look like the picture you linked?
Offline Pacifist
  • on hiatus
« Reply #2 on: Wed, 30 April 2014, 20:43:45 »
pretty sure it will....kc PBT is quite thin...even vortex PBT has bleed like that. Only thick Cherry caps have I seen only underglow
Offline da20valve
« Reply #3 on: Wed, 30 April 2014, 20:48:49 »
I want to have a backlit keyboard with rainbow keycaps, will it look like the pic ??, or is that for illustration purposes), I am not convinced if I buy rainbow keycaps they will be that transparent and show that much light
Wish they made backlit rainbow keycap board.
Offline Pacifist
  • on hiatus
« Reply #4 on: Wed, 30 April 2014, 20:50:08 »
they should be thin enough
Offline da20valve
« Reply #5 on: Wed, 30 April 2014, 20:58:35 »
I'm getting it, the only downside is you have to buy both the keys and the board, but oh well.
That's a nice Polar BTW,
Offline minho
  • i'm kind of back
« Reply #6 on: Wed, 30 April 2014, 22:06:33 »
How about the 2nd gen vortex doubleshots? Are they thicker or same thickness as the original ones?
Offline Pacifist
  • on hiatus
« Reply #7 on: Wed, 30 April 2014, 22:07:11 »
I dont own any, but for 1st gen it bleeds through the walls
Offline Lain1911
  • God of the Wired
« Reply #8 on: Wed, 30 April 2014, 23:24:43 »
Currently unavailable?
