Author Topic: Best Gaming Keyboard-pls advice me guys  (Read 1522 times)
Offline mastek
« on: Thu, 01 May 2014, 03:45:39 »
Hello. This is great forum.
I built new gaming PC. (%80 Gaming %20 Office etc.)
I have already Zowie Celeritas with Cherry MX Red Keys.
What is keyboard switch (or) type for gaming ? Topre or cherry?
Sould I buy a Topre keyboard for best gaming?
I interested this keyboard.
http://www.keyboardco.com/keyboard/topre-type-heaven-104-key-usa-45g-black-keyboard.asp
Zowie vs topre ? Which one?
Pls help me keyboard genius guys !
Offline Defect
Re: Best Gaming Keyboard-pls advice me guys
« Reply #1 on: Thu, 01 May 2014, 05:42:19 »
There are tons of these threads, so you may want to read others to see people's opinions.  At the end of the day what matters most is that you get what you want and you get what works for you.  But a few things to consider:
Layout:
60% - Bad for gaming IMO.  I still do it because I love the aesthetics of a 60% board, but this thing is really missing a few important things for gaming (ex: standalone F-Row).  Boards to look for: Poker X, Poker II, Pure, Korean Custom
Mini/75/84 (many names, not sure correct one) - My personal favorite for gaming.  Example:
People complain that the layout takes some getting used to (it does, but is totally worth it IMO), and the keycaps are annoying to replace on these boards.  Boards to look for: Noppoo Choc Mini, Keycool 84, KBT Race (and Race 2).
TKL - I respect this layout as the best all purpose layout for the average users.  However, I'd prefer 60% and mini layouts.  Again, PERSONAL PREFERENCE.  Some people here hate 60, hate compact, and love TKL.  YMMV
Full Size - Disadvantage is that the board is oversized and forces your mouse hand farther away from your QWER/WASD/1234 hand (commonly called the left hand).  Most games do not require a numpad, and numpads can be bought separately.
Switch Stem:
Linear: Red/Black - Perfect for FPS.  The keys actuate about half way down the press, so you can "hover" the sweet spot for easy multi tapping and awesome WASD control.  I do not like it for RTS as much unless I've practiced with linear for maybe a week to get used to it again.  Then linear is my favorite for RTS also.
Tactile (Low): Brown - Not very tactile IMO.  I much prefer clears.  However, browns start their tactile point a little bit down the key press, rather than at the top like clears
Tactile (High): Clear - Much more tactile than browns. The bump is so much bigger that with light springs the key gets stuck on the upstroke.
Clicky: Blue/Green - Bad for gaming.  Anyone who says otherwise has not looked at how the switch is designed.  Don't get me wrong, you can still game in blues.  However, in order to get accurate clicky feedback, you need to release the key all the way to reset the click mechanism.  Hovering is still possible, but you do not get the click if you hover and fail to fully release the key.  Some people game better in blues.  I will say that is very true, you can game on blues.  But do not try to argue that they are poorly engineered for gaming.  It's like saying you can run in basketball shoes, some people prefer running in basketball shoes, but they are poorly designed for running (heavy, much ankle support, etc etc etc).
Clicky (Soft): White: I'm still looking into it (you can find other people's answers on this forum), but I cannot explain why white switches are a softer click than blues.
Springs:
Red/blue/brown all share the same light-actuation spring
Back/green/white all share the same heavier spring
Clears have a very unique spring which is lighter than black spring for the first half of the press, but becomes much heavier the farther down you go in the press.  Hard to explain.
Low quality photo of common cherry switches:
Topre is a whole nother topic.  People say Topre isn't great for gaming, but honestly I've gamed on all switches and gaming on any switch is doable.  Personally I do not recommend Topre until you have tried many MX.  Topre is a great switch, I love it, but I would not recommend it as a first or as an only keyboard.
Try them all, collect them all, love them all.  Hope this helps, sorry if spam.
« Last Edit: Thu, 01 May 2014, 05:44:01 by Defect »
Offline Oobly
« Reply #2 on: Thu, 01 May 2014, 05:58:19 »
Short answer: Keep the Celeritas.
Longer answer: What types of games do you play? See the post above. Defect covered most of the relevant info.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline mastek
« Reply #3 on: Thu, 01 May 2014, 08:49:00 »
Thanks for all replies. I will think about it
Offline Fragil1ty
  • Abre los ojos.
« Reply #4 on: Thu, 01 May 2014, 09:10:27 »
In my eyes right now there are only two options for gaming.
The TKL and the 75% boards.
Here are my recommendations.
75% - Noppoo Choc Mini with Reds, I wouldn't bother with any other switch in this board, but that is just my personal preference.
TKL - Either the Razer BWTE /w Orange switches or the Filco TKL /w a switch of your choice, preferably Browns or Reds.
As previously explained, you need to ask yourself what are you going to be playing. The general consensus is = fps/spam games = Reds and RTS/Mobas etc = Browns/Oranges.
But at the end of the day the choice is always going to be down to you and what your own personal preferences are.
Good luck.
你搞砸了
