Author Topic: Best place to get Cherry Stab Plate Mounted  (Read 3266 times)
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« on: Thu, 01 May 2014, 08:47:43 »
      Hello. How are you?
      I am going to building phantom keyboard but i don't have Cherry Stabilizer Plate Mounted :(. If you know, please help me :D
      Thank you
Offline Flyersfan1
  • Hi!
Quote from: Photekq
Re: Best place to get Cherry Stab Plate Mounted
« Reply #2 on: Thu, 01 May 2014, 09:26:37 »
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #3 on: Thu, 01 May 2014, 09:32:15 »
What is the biggest difference between them? Sure the plate mounted ones actually hook onto the plate but other than that is there a reason why these wouldn't work?
|||My other keyboards :
x
Offline Defect
« Reply #4 on: Thu, 01 May 2014, 09:37:52 »
PCB mount stabs...mount on the pcb.  There's holes in supporting PCBs for these.  Plate mount do not go past the plate AFAIK.
« Reply #5 on: Thu, 01 May 2014, 09:38:02 »
PCB mount ones have clips underneath them that allow them to attach to the PCB. Plate mount ones don't. They instead hook onto the plate as you said. Those are the only differences.
Offline bazh
« Reply #6 on: Thu, 01 May 2014, 10:08:59 »
PCB mount stabs need supported holes on PCB to work, if the PCB don't have these, you got to go with plate mount
« Last Edit: Thu, 01 May 2014, 10:16:22 by bazh »
HHKB Pro2 white
Newbie again
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #7 on: Thu, 01 May 2014, 10:14:08 »
I have all types lying around. Even old style screw mounted ones. I'll check them when I get home. Something tells me you don't need plate-mounted ones if the pcb has the extra holes.
I'll report back later.
x
« Reply #8 on: Thu, 01 May 2014, 10:21:05 »
Let me know if you want to sell any of those old screw mount ones! ;D
« Reply #9 on: Thu, 01 May 2014, 10:21:48 »
That is correct but the phantom PCB does not have the holes, so you have to use plate mount. :(
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #10 on: Thu, 01 May 2014, 10:45:28 »
Probably not. I'll be using them myself. ;D
Well, either that, or Costar ones.
« Last Edit: Thu, 01 May 2014, 10:47:19 by JaccoW »
x
  • Frenzy Classic.
« Reply #11 on: Thu, 01 May 2014, 11:15:40 »
Yeah i have 2 phantom pcb and i 'll use 2 type stabilizer for they: Costar & Cherry  ^-^
Offline bazh
« Reply #12 on: Thu, 01 May 2014, 11:49:24 »
I'm doing desoldering my MaxKeyboard for switches, there will be enough stab (Costa) for a full size board. I was planning on using them for future projects but if you need them, just wait for me a couple of days (well, lazy problem) till the work done then I'll send you for free ;)
Edit: I'm not sure about the wire of spacebar stab, MaxKeyboard uses 6x spacer so maybe it wont fit on 6.25 but then you could just bend a new one :))
« Last Edit: Thu, 01 May 2014, 11:52:20 by bazh »
HHKB Pro2 white
Newbie again
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #13 on: Thu, 01 May 2014, 14:04:40 »
Sadly I think he's put for the cherry plate mounted not costar! Really kind of you though!
