Author Topic: Still searching.  (Read 2706 times)
Offline PurpleFurple
Still searching.
« on: Thu, 01 May 2014, 16:28:17 »
Okay im basically looking for the cm storm quickfire (backlit) without the very ugly font. Suggestions?
Thank you in advance
PurpleFurple
« Last Edit: Thu, 01 May 2014, 16:43:54 by PurpleFurple »
Offline lightsout714
Re: Still searching.
« Reply #1 on: Thu, 01 May 2014, 16:38:11 »
By a rapid and some custom caps? Or get a filco/ducky etc?
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #2 on: Thu, 01 May 2014, 16:38:40 »
Buy other caps?
Edit: Ninjad
« Reply #3 on: Thu, 01 May 2014, 16:44:45 »
Buy other caps?
Edit: Ninjad
Well i live in the eu and getting some other good keycaps is pretty hard.... and especially keycaps for backlighting
« Reply #4 on: Thu, 01 May 2014, 16:51:47 »
Oh sorry i missed the backlit part. Maybe just buy a ducky shine then? If you like those keycaps.
Offline Signature
  • master of puppers
  • snoozing
« Reply #5 on: Thu, 01 May 2014, 16:52:18 »
Buy other caps?
Edit: Ninjad
Dont get an ISO or buy duckys keycaps for backlightning
« Reply #6 on: Thu, 01 May 2014, 16:54:30 »
Well i have looked at quite some things and in the Netherlands the ducky shine is a bit too expensive. In comparison in the us it costs 130 in the Netherlands 210 dollars thats the difference
« Reply #7 on: Thu, 01 May 2014, 17:09:58 »
Keep an eye on the classifieds here. Although shipping will be pretty expensive.
« Reply #8 on: Thu, 01 May 2014, 17:32:14 »
So you have no suggestion for a (very) solid mx brown/blue backlit mechanical keyboard with a reasonable price wich is not a cmstorm?
« Reply #9 on: Thu, 01 May 2014, 21:29:28 »
You might want to start a new thread with your question in the title. If you are hoping for a backlit at the price of a QFR theres probably not much out there. They are priced really well.
This site has a few just to see whats out there.
https://mechanicalkeyboards.com/search.php?keyword=&switch_id=ALL&size=Tenkeyless&man=ALL&key_plastic=ALL&backlit=ALL&interface=ALL&cord_length=ALL&usb_kro=ALL&ps2_kro=ALL&x=17&y=13&in_stock=on
