Author Topic: IBM 3270 drivers for Windows 7?  (Read 1513 times)
Offline zig_ziglar
« on: Thu, 01 May 2014, 17:18:14 »
Anyone had any luck finding or developing drivers for this? Apparently the 122 key Emulator Model M is capable of sending unique scancodes, but requires OS driver support to do so.
Cheers
Re: IBM 3270 drivers for Windows 7?
« Reply #1 on: Thu, 01 May 2014, 17:45:00 »
The IBM 3270 is a beam spring model. You will have to replace the controller to get it to work on USB.
It's actually quite distant from the 122-key keyboards for the 3180 and 3179.
Offline zig_ziglar
« Reply #2 on: Thu, 01 May 2014, 17:51:46 »
Ughh. I think this marks the point in time where I give up lol
No 122 keys for me..
http://geekhack.org/index.php?topic=57406.30
As you can see if you want to read this other thread of mine, it's like getting blood out of a stone getting a plain English answer about these keyboards. It's almost as though Unicomp and the elitist M club don't want non-geeks having functional 122 boards... :/
« Last Edit: Thu, 01 May 2014, 17:56:38 by zig_ziglar »
« Reply #3 on: Fri, 02 May 2014, 07:30:56 »
Old M-122s are plentiful and cheap. With the right plugs, they have always worked for me with Soarer's Teensy without any drama. Plus, your re-mapping can be programmed into the Teensy itself.
If you weren't in OZ I would sell you a naked M-122 without the top case for pretty cheap. I think it has a "RJ-45" (loosely speaking) connector but making an adapter is not too hard, or it could be hard-wired.
- Franklin Roosevelt 1933
