Author Topic: Discrete Buckling Spring Keyswitches?  (Read 8143 times)
Offline krfkeith
« on: Sat, 03 May 2014, 01:25:17 »
Did any company ever make anything like this? Conversely, is this something, through the magic of 3D printing or whatever, an individual could make themselves?
Re: Discrete Buckling Spring Keyswitches?
« Reply #1 on: Sat, 03 May 2014, 01:33:51 »
Do you mean like an individual switch?  No company I know of does this currently.  Buckling spring generally relies on an underlying membrane, so discrete switches are not made.
Offline tbc
« Reply #2 on: Sat, 03 May 2014, 02:12:59 »
kinda sounds like he just wants a keycap holder like all those topre and mx keychains...hell, i might get one.
Offline krfkeith
« Reply #3 on: Sat, 03 May 2014, 02:19:59 »
Yeah, exactly, individual switches. Hmm, I'd have to read up on the exact mechanics of the BS, but could the switches use individual membranes? Alternatively, could the Model F style capacitive types be done in individual switches?
Offline Oobly
« Reply #4 on: Sat, 03 May 2014, 02:31:48 »
You could probably cut one out of a full keyboard minus the membrane and make your own case and single membrane for it, but it would be a fair bit of work, IMHO.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline False_Dmitry_II
« Reply #5 on: Sat, 03 May 2014, 02:35:01 »
THERE IS such a thing as Alps Buckling Springs, but they are extremely rare, and very expensive.
http://deskthority.net/wiki/Alps_buckling_spring
« Reply #6 on: Sat, 03 May 2014, 02:45:02 »
The Model F's switches and the Brother switch have individual barrels, but they rely on capacitative sensing and membrane respectively.
Sure, I think that you could 3D-print plate-mounted barrel modules with a good 3D printer. I think that the shaft would need to be very smooth and precise for the switch to feel any good and that might be tricky to achieve with a regular home 3D printer .. but challenges are there to be overcome.
Edit:
I don't think the switches are discrete, but all of them are sharing the same barrel plate like on regular Model M and most rubber domes.
« Last Edit: Sat, 03 May 2014, 02:50:51 by Findecanor »
Offline wcass
« Reply #7 on: Sat, 03 May 2014, 10:15:57 »
This was the idea behind my XTant project; harvest the discrete components of an IBM XT keyboard (barrels, springs, flippies, case) and replace the top metal plate and cap sense PCB to match a re-arranged key layout. Custom membranes are expensive (about $100 for a 60% layout) and custom capacitive PCB has not been done successfully yet (but progress is being made).
http://deskthority.net/workshop-f7/bringing-the-ibm-pc-xt-into-the-21st-century-t3047.html
http://geekhack.org/index.php?topic=51767
http://geekhack.org/index.php?topic=40111
« Last Edit: Sat, 03 May 2014, 10:20:52 by wcass »
Offline RabRhee
« Reply #8 on: Sat, 03 May 2014, 10:32:49 »
There have been a couple of keychain versions as I recall, someone on Deskthority had a key testing set that included a buckling spring tester. Plus there is this one of mine...
63476-0
It has a piece of the membrane cloth, and the base of the switch is made from a piece of the baseplate, primarily to try keep the sound authentic. I guess if one piece of membrane was cut out (3 thicknesses) then it could perhaps be a functional switch. For now its just for reasonably accurate sound and feel.
edit: Basically, cropping a discrete switch out of a Model M is possible, but yes it was a bit of messing around. I reckon it could be possible to make the switch functional, again with more messing. I wouldn't like to make a stack of them to build into a new board though.
« Last Edit: Sat, 03 May 2014, 10:52:16 by RabRhee »
-Life is good-          Crafting: |  KeychainsMore.   .Keychains | Crowdsource Key | Budget Keycap Board |
Offline krfkeith
« Reply #9 on: Sat, 03 May 2014, 10:58:12 »
Fascinating! I've been skimming those threads. How did you manage/how were planning to fabricate the metal plate?
Offline wcass
« Reply #10 on: Sat, 03 May 2014, 11:18:04 »
CAD software to design; laser service to cut. A local HVAC shop ran it through a slip roll (for free!) to get the curve just right. That middle link has the most detail on that part.
« Reply #11 on: Sat, 03 May 2014, 11:51:32 »
So is the project alive?
I will start scavenging for junk XTs if need be, and/or it would be great if AT/122 barrels could be accommodated, too.
« Last Edit: Sat, 03 May 2014, 18:31:56 by fohat.digs »
- Oliver Willis 2026-08-01
Offline wcass
« Reply #12 on: Sat, 03 May 2014, 15:19:27 »
Yes, it is still alive, but is mostly in need of a controller. I'm hoping that the DPH will do the trick. I have measured a AT/122 barrel, so easy enough to cut a whole that would fit either post or notch type barrel. But AT and 122 are such nice boards, it would be a shame to use those.
63502-0
« Reply #13 on: Sat, 03 May 2014, 18:36:51 »
No argument there, but personally I have an XT and a 122 that were hopelessly trashed, so I have spare parts of both types. However, I have been selling them off in dribs and drabs, and at this point I would be lucky to have enough between them to do one board!
Offline 0100010
  • Not Sure
« Reply #14 on: Sun, 04 May 2014, 17:08:05 »
I've thought a few times about picking up a couple XTs to harvest the barrels.  Would need a custom designed plate, membrane and controller to make the potential layout I want though.
« Reply #15 on: Sun, 04 May 2014, 17:14:12 »
and you'll need two XTs to make it.
It may be possible to make a capacitive version of it with the new DPH controller or xwhatsit's controller. That's the dream anyway.
