I was only interested in the glowy keys. $13 for the set of 4 seemed perfectly reasonable to me. I liked them all.
Sucks that it didn't tip.
Fortunately the glowing one didn't tip, I would have had to shell out the $45 dollars per legend ($180.00) in order for the set to be made. That cost is put into the first 25 which was why the parent deal was so much. All my future GB's will be separate parent deals.
I wanted the rabbit more than I wanted the pills. Also my keyboard is ANSI150 so I'd have to put the 1.25 keys somewhere odd ... or more likely on my ergodox.
What size would have been good for your modifiers on your ANSI150? 1x1.5?
Also, I am thinking of running the group buy again now, but this time having a single Rabbit key by itself with a glowing variant with it, the Red and Blue pills in 1x1.25 PC, and then a version of Red and Blue pills in 1x1 Red and Blue ABS. Like how they did the banner keycaps below:
![[IC] The Matrix Novelty keycaps - ABS Double Shots... 73636-0](https://geekhack.org/index.php?PHPSESSID=elbbga2oe6ages3lvtoqkh7617n2s8r6&action=dlattach;topic=57916.0;attach=73637;image)
Though I am not sure I want the same profile...maybe Row 4 DCS 1x1...
