Author Topic: Cut PCB mount stabs to work with Phantom?  (Read 2013 times)
Offline Pacifist
  • on hiatus
« on: Tue, 06 May 2014, 15:53:11 »
Would it be possible to cut off the inserts on PCB mounted cherry stabs then glue them to the PCB of a phantom? Orr is it just not sturdy enough?
Re: Cut PCB mount stabs to work with Phantom?
« Reply #1 on: Tue, 06 May 2014, 15:54:20 »
You'd be better off making holes in the PCB for the stabilisers. Cherry plate mount stabilisers feel pretty much identical once they're clipped.
Offline Pacifist
  • on hiatus
« Reply #2 on: Tue, 06 May 2014, 15:57:48 »
Hmm okay. I've read that clipping plate mount cherry stabs doesn't actually do anything. Looks like it actually does.
« Reply #3 on: Tue, 06 May 2014, 16:00:45 »
It does the exact same thing as clipping PCB mount stabilisers. The stem on plate mount stabilisers hits the PCB, just like the stem on PCB mount stabilisers.
« Reply #4 on: Tue, 06 May 2014, 16:01:05 »
Besides the spacebar do you really need stabilizers bad enough to attempt gluing them to the PCB?
« Reply #5 on: Tue, 06 May 2014, 16:47:44 »
Not really. And it's too bad that drilling holes for the spacebar stab in the Phantom PCB is a no-go. There are traces that run through there.
« Reply #6 on: Tue, 06 May 2014, 16:57:24 »
Could they not be bridged?
Offline Pacifist
  • on hiatus
« Reply #7 on: Tue, 06 May 2014, 17:39:15 »
tried clipping the stabs on my new(ish) deck legend, and I see now that plate mount cherry stabs are affected by clipping the same way pcb is.
Thanks for the help! Going to go with plate mount for next build
