Author Topic: Ordered Surface Pro 2 plus Poker 2. Now I need a bag or something...  (Read 2522 times)
Offline roaming pear
  • THE Roaming Pear
So, I have ordered both of these items and now I'm thinking about the best way to carry these items with my while protecting them both?
So I need some help figuring it out and deciding..
-  Should I put a screen protector on the surface?
- I'm not getting a touch cover for the surface so if I place it together with the poker, then They'll scratch each other, or at least the poker will scratch the surface of the surface....      ._.
- So what, should I get to protect both items?
- I have a few bags I can proabably put both the surface and the poker in, but I'm guessing I need at the very least a sleeve for both items... What would you recommend me using?
Thanks
Does anyone have any accessories or key caps or other poker 2 related things lying around that they are not using?  I don't mind taking it off your hands if you no longer want it...
Offline blighty
http://www.amazon.com/Manvex-Microsoft-COMPATIBLE-Keyboards-Multiple/dp/B00BYTGLFY/ref=sr_1_1?ie=UTF8&qid=1400162782&sr=8-1&keywords=surface+pro+2+case
I use this cover, works well enough.  If you don't plan on using a touch or type cover, this case http://www.amazon.com/Incipio-Capture-Microsoft-Surface-MRSF-053/dp/B00GUXH5MM/ref=sr_1_8?ie=UTF8&qid=1400162782&sr=8-8&keywords=surface+pro+2+case would be perfect.  As for bag, I just use whatever laptop bag that has enough space for what I want to carry that day...
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
