Author Topic: Post Pictures Of Your Desk/Set Ups!  (Read 2369965 times)
Re: Post Pictures Of Your Desk/Set Ups!
« Reply #5550 on: Fri, 16 December 2016, 21:21:30 »
any one have tips for better ergonomics using 3 monitors, my neck is killing me...
Offline henz
  • What?
« Reply #5551 on: Sat, 17 December 2016, 04:38:22 »
sell them, i did, got one 24 inch instead =), as a linux user i instead make use of the different workspaces. Im thinking of getting a 30inch screen now, but i dont really feel like putting up the money for it.
Offline davkol
  •  Post Editing Timeout
« Reply #5552 on: Sat, 17 December 2016, 07:14:16 »
That depends on their size and layout. I can take three 20" (4:3) screens as PPP or one 30" (16:10) screen with one or two of the former as PLP, and it's alright. Anything more is too much for me (namely, LLL or PPP with larger widescreens).
Offline limitz
  • "the old gods stir and will not let me sleep..."
« Reply #5553 on: Sat, 17 December 2016, 14:47:27 »
Assuming you have 3x 27", 1440p monitors. Then center monitor in landscape, 2x in portrait flanking it..
Mmm... machined aluminum
Offline Brammm87
« Reply #5554 on: Sat, 17 December 2016, 17:33:08 »
Have you considered an ultrawide? I was on the fence between double monitors or ultrawide and went with the latter. Not changing back. I have a 34" Dell ultrawide. That 38" LG one looks super awesome as well.
pls gief bbv2
« Reply #5555 on: Sat, 17 December 2016, 22:45:19 »
i need centre 144hz 24" for gaming, other two are IPS panel 21" in landscape for productivity (yes I use all 3 actively). I want to put them in portrait but they're really cheap **** monitors that don't have much adjustment (and a non-standard mounting bracket so i'd have to get an adapter -_-)
ultrawide is a no go unfortunately
best i could do is push them back a little further
Offline Brammm87
« Reply #5556 on: Sun, 18 December 2016, 05:10:10 »
Hmm, good point. Do you do all on the same machine? I do work on a MBP and gaming on a PC. The ultrawide was a bit of a compromise for me. I've been thinking of switching to just separate setups, a 144hz for gaming and the ultrawide for productivity... But you need a lot of desk space for that.
pls gief bbv2
Offline davkol
« Reply #5557 on: Sun, 18 December 2016, 07:09:12 »
Even some cheap monitors have 75mm VESA MIS mount on the back.
However, I'd just replace both of those suckers by one ~32" screen.
Offline vyshane
« Reply #5558 on: Tue, 20 December 2016, 09:08:12 »
New addition to my home development setup: A 5 node Kubernetes cluster built using Nano ITX boards. 16 physical cores, 40GB of memory and 720GB of SSD storage. 3 of the nodes are passively cooled J1900 Celerons and 2 are dual-core i3s. Low power consumption was one of the main design goals for the build.
I'm running Ubuntu 16.04 as the base OS.
Offline joey
« Reply #5559 on: Tue, 20 December 2016, 09:14:20 »
What's that thing that looks like a little laptop underneath all of them?
Offline vyshane
« Reply #5560 on: Tue, 20 December 2016, 09:22:46 »
SSD
Offline Mavarina
« Reply #5561 on: Tue, 20 December 2016, 10:26:24 »
Here's my setup atm:
and my keyboard stuff:
Offline joey
« Reply #5562 on: Tue, 20 December 2016, 10:29:57 »
SSD
Ah. Pretty cool!
Offline ctrlX
« Reply #5563 on: Tue, 20 December 2016, 12:02:14 »
Really cool. What manufacturer and model are those ITX boards? Looking for something similar as my RPi's are not cutting it.
Offline vyshane
« Reply #5565 on: Tue, 20 December 2016, 18:01:04 »
They are Nano ITX boards from Qotom:
With quad-core J1900 Celeron
With dual-core i3
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #5566 on: Wed, 21 December 2016, 06:48:34 »
Ahh, that's awesome! What're you using it for?
Offline funderburker
« Reply #5567 on: Wed, 21 December 2016, 07:25:06 »
I'm too interested. Always fun to find out about development setups.
Keyboard design by Skepur
Offline vyshane
« Reply #5568 on: Wed, 21 December 2016, 08:30:08 »
I deploy the server side applications that I build to Kubernetes. This is going to be my development cluster. I'm planning to run Concourse CI, Prometheus, Open Tracing, Zookeeper, Kafka, various databases.
Any why not, household things like Plex server too :) It's just a bunch of compute. If I can containerise an app, I can just chuck it on there.
Offline menuhin
« Reply #5569 on: Thu, 22 December 2016, 11:49:52 »
I've recently been thinking:
Is a modern desktop computer more powerful?
OR
If I spent the same amount of money to build a cluster like this (e.g. or from Raspberry Pi) be even more powerful?
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline vyshane
« Reply #5570 on: Fri, 23 December 2016, 10:11:14 »
OR
It depends on your use case. Less nodes (or even just one) but with better performance per core? Or more nodes (and cores), but less performance per core?
For my use case, I want to be able to run a lot of containers to replicate a production-like setup. However, since this is a development environment, it will not see actual production-like load. So single core performance isn't that important. More cores is more useful for my use case.
You can always mix and match node configurations to get the optimum setup. If you are using Kubernetes, you can let it know that specific nodes have better single core performance, and set pod affinity to these nodes for applications that need the performance. For example, maybe I want CI build workers to complete builds faster. I could add a node with an i7, and tell Kubernetes to schedule the workers on the i7 whenever possible.
I didn't seriously consider Raspberry Pis because they don't have enough memory to effectively bin pack containers. Plus a lot of apps require x86.
Offline menuhin
« Reply #5571 on: Fri, 23 December 2016, 10:31:19 »
I also need x86/x64 support for many packages I rely on.
That's why I'm not sold to the Raspberry Pi yet unless I want to build some robotic toy or cheap home media console.
I (or where I work?) attract dust a lot and am quite lazy to clean them regularly, and this is another factor that let me rethink if a cluster is good for me.
IBM M13 black
HHKB Pro 2 HasuBT
Offline Hordak
« Reply #5572 on: Sun, 25 December 2016, 11:29:57 »
I need a new desk bad.
156089-0
Offline kyotost
« Reply #5573 on: Sun, 25 December 2016, 22:47:32 »
awesome case!!
Offline ramnes
  • T fou, mec?
« Reply #5574 on: Wed, 28 December 2016, 04:08:03 »
i want a case like that
Yeah, what case is that?
Offline rabbitfire
« Reply #5575 on: Wed, 28 December 2016, 04:52:42 »
thermatake core P5. The smaller version is core P3. Color: black, white (Snow edition).
Offline Hordak
« Reply #5576 on: Sat, 31 December 2016, 15:01:17 »
awesome case!!
Thanks! Got a bit too crazy with that build ;D
Offline childofthehorn
« Reply #5577 on: Mon, 02 January 2017, 15:11:45 »
Just my daily keyboards I switch between (but not my full collection).
Top - WhiteFox with 62g Zealios and socketed, colored LEDs, Nantucket Selectric caps
2nd - HHKB style Matias QC custom with Cherry Wood plate and Alpine Winter caps
3rd - HHKB with BT Hasu controller
Bottom - FaceW with RGB lit case and switch LEDs, 62g sprit Gateron Blues (lubed), purple plate, GMK mods, JTK PoW keyset, various artisans
Offline reaper
« Reply #5578 on: Mon, 02 January 2017, 19:27:16 »
My current setup...
Din Eli
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #5579 on: Mon, 02 January 2017, 19:43:15 »
My current setup...
Dopest setup ever. Where can I get one of those monitor stands?
Offline reaper
« Reply #5580 on: Mon, 02 January 2017, 19:44:12 »
My current setup...
Ralph's, Vons, Bed, Bath & Beyond, etc.  They all offer different color stands.
Din Eli
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #5581 on: Mon, 02 January 2017, 19:52:01 »
My current setup...
Which ones will be most sturdy to support multi monitor setup?
Offline reaper
« Reply #5582 on: Mon, 02 January 2017, 19:55:28 »
My current setup...
 :thumb:
Din Eli
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #5583 on: Mon, 02 January 2017, 20:25:27 »
My current setup...
 :thumb:
Holy ****, that's awesome!
Offline Moistgun
  • Slippery When Wet
« Reply #5584 on: Mon, 02 January 2017, 21:55:30 »
My current setup...
Costco have an extra large version if you are on 21:9
Offline hanoipho
« Reply #5585 on: Tue, 03 January 2017, 06:15:46 »
My Setup156695-0
Offline rabbitfire
« Reply #5586 on: Tue, 03 January 2017, 06:38:21 »
My Setup (Attachment Link)
wow! nice setup! what ram do you use? are you an OW fan? I saw your OW mice, pad and headphone.  ;D
« Last Edit: Tue, 03 January 2017, 06:40:31 by rabbitfire »
Offline hanoipho
« Reply #5587 on: Tue, 03 January 2017, 06:44:23 »
Haha yes I'm OW big fan, playing like 5-6 hrs everyday. I'm using averxir raiden series 2*8gb
Offline aaron6301
  • Pixel Pusher
« Reply #5588 on: Thu, 05 January 2017, 19:29:05 »
The home office/play area
Offline Jokrik
« Reply #5589 on: Thu, 05 January 2017, 19:49:53 »
Nice setup! very cooling and comfy looking
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #5590 on: Thu, 05 January 2017, 20:12:45 »
Nice little mini desktop build you got there!
Offline aaron6301
  • Pixel Pusher
« Reply #5591 on: Thu, 05 January 2017, 21:48:17 »
It's actually my first build too. Quite happy with the results  :thumb:
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #5592 on: Thu, 05 January 2017, 21:53:42 »
Very nice. Specs?
Offline sek1ne
  • Sek-eye-n
« Reply #5593 on: Thu, 05 January 2017, 22:47:09 »
That is a very nice set up. I really dig the light up mouse pad.
Biking is fun.
Offline aaron6301
  • Pixel Pusher
« Reply #5594 on: Thu, 05 January 2017, 23:58:29 »
Very nice. Specs?
-i7 6700k
-Corsair H100i V2
-MAXIMUS VIII GENE
-Corsair Vengence LPX 32GB DDR4
-850 Evo 500GB
-EVGA 1070 SC (1080 soon)
-Corsair Air 240
-RMx 650W 80+ Gold
-NZXT Hue+
Sent from my SAMSUNG-SM-G925A using Tapatalk
« Reply #5595 on: Fri, 06 January 2017, 00:38:09 »
feels so weird going back to 2 monitors at work compared to3 at home
Offline dante
« Reply #5596 on: Fri, 06 January 2017, 21:26:34 »
^ first world problems.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #5597 on: Sat, 07 January 2017, 07:01:40 »
That's why I stole a third monitor at work while no one was looking =]
Very nice. Specs?
-i7 6700k
-Corsair H100i V2
-MAXIMUS VIII GENE
-850 Evo 500GB
-Corsair Air 240
-RMx 650W 80+ Gold
-NZXT Hue+
Pretty solid. Especially for a first build  :thumb:
« Reply #5598 on: Sat, 07 January 2017, 07:06:33 »
nice I got a h100i v2 as well, gonna push the 2500k to 4.8
new rig:
https://ca.pcpartpicker.com/user/sifo/saved/#view=nyx999
might consider SLi 1080s in the future.
streaming PC is gonna be beast too though:
2500k to 4.8ghz
H100i V2
MSI P67A-GD65
Corsair GS800
2x4GB G.Skill Ripjaws 1600 DDR3
2x R9 285
HAF912
128GB 850 EVO and WD Black 1TB
all funded by bitcoin (and some misc stuff like a video card for friend, 144hz monitor, datavac)
<3
« Last Edit: Sat, 07 January 2017, 09:54:38 by Sifo »
Offline Jokrik
« Reply #5599 on: Sat, 07 January 2017, 20:47:12 »
Current Setup by Hanshen, on Flickr
:) on a relaxing Sunday morning
