Author Topic: LED Mod for Topre Board?  (Read 1944 times)
Offline esko997
  • Linux Lover
« on: Thu, 08 May 2014, 22:48:11 »
Hey all,
The board in question would be the Leopold FC600C. I just got it the other day, and I'm loving the board, but couldnt find any information via a site:geekhack.org Google seach or through the sites search bar about adding LEDs to Topre boards.
Is this idea just impossible due to the way Topre boards are built?
Any insight appreciated.
Thanks,
Esko997
Daily Drivers:  Unicomp Customizer (BS -- Linux Layout) | Vortex Race 3 (Clears)
Other Boards: CM Quickfire Stealth (Greens) | Poker II (Blues) | PLU-ML 87 (Ergo Clears)  | JD40 (Browns) | Leopold FC660C (Topre) | IBM Model M | ErgoDox (Clears) | Sentraq s60x DIY (Blacks) | Anne Pro 2 (Blues) | Cherry G80-11900 (Blacks) | Kira (99 Key) (Hako True)
Re: LED Mod for Topre Board?
« Reply #1 on: Thu, 08 May 2014, 23:27:29 »
it's possible but difficult.
You would have to either reverse engineer the PCB with LED backlight support or hand-wire a matrix yourself. #1 has a lot more functionality, #2 is easier. either option would be really difficult.
« Reply #2 on: Thu, 08 May 2014, 23:38:52 »
How do you hand wire a topre board?
Offline user 18
« Reply #3 on: Thu, 08 May 2014, 23:56:23 »
My guess would be with hands and with wires. I suppose you'd need to add resistors, diodes, etc. to get everything to work all nice-like. You might also need to mod the case to fit the rat's nest of wires into the physical space.
Solution: Buy a poker 2, LED mod it, and ship me all your topre :P
Avatar by ashdenej
Offline tbc
« Reply #4 on: Thu, 08 May 2014, 23:59:59 »
how safe it is to add backlights to the PCB so that you shine through the gaps between caps rather than through the legends?  put some electrical tape down, put the LED on top, put some clear tape over it and hope for the best?
Offline user 18
« Reply #5 on: Fri, 09 May 2014, 00:14:10 »
I don't think you can physically fit much on top of a PCB and below the keycaps. Consider that you have to be able to depress the keycaps too, and if any depressed keycap doesn't work with your idea, it's as good as useless.
Avatar by ashdenej
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #6 on: Fri, 09 May 2014, 01:29:43 »
To my knowledge hand wireing the switches won't work on this board.  IIRC the C designates capacitive, so that would be topre switches.  It is a lot more work than just switches, and diodes.  For what its worth I am thinking of doing a backlight mod to a Model M using EL tape.
