Author Topic: [IC] Tai Hao Alps Keysets (Color and Layout Poll is up)  (Read 20444 times)
Offline Hak Foo
  • Make America Clicky Again!
Re: [IC] Tai Hao Alps Keysets (Color and Layout Poll is up)
« Reply #50 on: Wed, 21 May 2014, 00:52:25 »
Does SP even have all the sizes for ALPS?
OTOH, if they can do DSA ALPS, that probably streamlines selection quite a bit.
Overton130, Box Pale Blues.
Offline Pacifist
  • on hiatus
« Reply #51 on: Wed, 21 May 2014, 00:54:07 »
I have my doubts about hitting 500 for an alps buy. But if we can go with SP with a slightly higher cost but a realistic MOQ, that would be best. Unfortuantly there aren't that many Alps lovers
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #52 on: Wed, 21 May 2014, 00:59:52 »
Good idea.  More color scheme options also.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline Hak Foo
« Reply #53 on: Sat, 24 May 2014, 01:30:06 »
If anyone cares still, they tore down the Rosewill board with Tai Hao switches.  I don't know if it's actually made by Tai Hao, or just uses their switches, but it appears to use ALPS-style stabilizers
http://geekhack.org/index.php?topic=58715.0;topicseen
Offline nuclearsandwich
« Reply #54 on: Wed, 28 May 2014, 14:55:02 »
Based on the number of survey responses (fewer people than in this thread) a 500 kit MOQ is not going to happen without vendor backing. I'm going to leave the IC open and start verifying that we can support plethorae of layouts and stabilizer configurations. I've also been disassembling old and new Alps boards to see what our stabilizer options can be and to start some 3D designs for making new stabilizer parts from Shapeways. I've got old Alps boards with fatty stabilizer mounts for the inserts and old boards that have MX stem style mounts for stabilizer inserts. It will take me some time to confer with Signature Plastics about the current state of their stabilized Alps tooling.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #55 on: Wed, 28 May 2014, 22:25:39 »
folks how many times have us ALPSZERS been doing this wrong just to see it fall all apart because we we all want everything-- there are a ga-zillion different alps lay-outs out there. Trying to figure the stabs, stems, etc is where we lose  the order and the people.
why can't we at just start with a base 54 or num pad or function row set that will tolerate 90% alps boards with all the various alps layouts
come back later date and maybe do the dell at101w mods if someone can do the stabs and stems, ducky 1087 anci, etc.
biut at "least" get moving on something that "can" be agreed onm as they are pretty much all the same.
somebody do something so we don't let one fail like the others.
add some special novelty key to be offered  with the kit.
maybe binge (or someone equal) would be willing to make a custom key for oiur first alps buy?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Techno Trousers
  • ʘ_ಠ
« Reply #56 on: Wed, 28 May 2014, 23:30:55 »
I'd be down for starting with a set of just the 1x keys to simplify and get the ball rolling. Sorry I didn't make time to fill out the survey. For what it's worth, I'd like to kit out two abs M1s (straightforward ANSI 104 layout), and maybe one or two Dell AT101Ws, although I know those have problematic modifiers.
« Reply #57 on: Thu, 29 May 2014, 00:53:32 »
That's good to know but it isn't data until it makes it into the survey so when you've got some time I'd really love you to record that. Thanks!
Offline Magna224
« Reply #58 on: Sat, 31 May 2014, 03:24:59 »
id be in.
« Reply #59 on: Mon, 16 June 2014, 22:34:18 »
Oh yay, a way to get keycaps!
I have a pile of ALPS whites and a set of doubleshots that I wanted to make a keyboard out of, but I'm missing some keys. I figured I'd just get a whole new set.
Offline gotofbi
« Reply #60 on: Sun, 22 June 2014, 15:25:29 »
I am down for couple sets
Offline geniekid
« Reply #61 on: Thu, 31 July 2014, 11:19:52 »
Filled out the poll!  I have lots of opinions on layouts and colors but none of them would be dealbreakers given how sparse the landscape looks for ALPS caps.
« Last Edit: Thu, 31 July 2014, 11:24:03 by geniekid »
