Author Topic: What switches are used in the Cherry 1800 line?  (Read 8524 times)
Offline jaydub
« on: Sun, 26 April 2009, 12:53:18 »
Does anyone know what switches Cherry uses for its 1800 compact keyboard line?
http://www.cherrycorp.com/english/keyboards/Industrial/1800/index.htm
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #1 on: Sun, 26 April 2009, 13:03:55 »
The models on the linked page are all with linear (black) MX switches - P with PS/2+USB combo or U with USB. Others are probably available if you're an OEM who'd like a thousand or two.
Offline IBI
« Reply #2 on: Sun, 26 April 2009, 13:13:19 »
Quote from: keyb_gr;87387
Actually the ones listed on that page as the G81s which use FTSC switches, but the G80-1800 do use linear MXs. (older ones may have non-linear ones, as well as custom bulk orders).
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline jaydub
« Reply #3 on: Sun, 26 April 2009, 13:18:29 »
What are the characteristics of an FTSC switch?
Also, it would appear that the only Cherry keyboard that uses Cherry Blues would be the G80-3000LSCRC-2?  Is that correct.  Odd, considering it is the maker of those switches.
« Last Edit: Sun, 26 April 2009, 13:21:04 by jaydub »
Offline keyb_gr
  • Cherrified user
« Reply #4 on: Sun, 26 April 2009, 14:10:18 »
Quote from: jaydub;87395
It's a plunger-over-membrane mechanism that gives a linear response and bottoms out quite softly. Some prefer it over blacks due to the latter, while others find it to be stiff.
Oh, a few years back you could pretty much only pick up 3000s with blacks, so the current situation is an improvement already (here in Germany, both white -0 and black -2 versions of the G80-3000LSCDE can be picked up). I guess the production capacities weren't there for overly many different versions, they make a lot of other things as well after all. I'd also assume the blacks to be the least expensive type of the bunch.
Which variants of the G80-3000 are currently made in Germany and which in the Czech Republic, don't ask me. Seems to be no distinct pattern.
Offline jaydub
« Reply #5 on: Sun, 26 April 2009, 14:58:26 »
Well, I have a Compaq KU-9963 which is a membrane board, non-clicky of course, but with a 55g peak force bump fairly high in the travel.  I have to say that I do like the action on this board, especially because of the bump.  I tried out the Filco with Cherry browns and it is nowhere near as tactile.  As far as mechanical non-clicky switches, it sounds like the Alps blacks are the only other game in town.  Are they significantly more tactile?  ABS M1 seems to be the most well known.  Are there compact alternatives?
Offline IBI
« Reply #6 on: Sun, 26 April 2009, 20:54:02 »
Quote from: jaydub;87410
Membrane is just the mechanism that registers the keystroke, it determines nothing about the feel, do you mean Rubber Dome?
If you do then I agree, I've got a rubber-dome gateway non-anykey that's very nice to type on. I wondered if yours was the same keyboard, but looking at a picture it appears to be a lot newer
If by 'tactile' you mean a sudden change in the feel as the switch goes down (i.e. a silent click) then no, or at least not for the real alps. (They're very nice though). I don't think any of the mechanical switches give the collapsing behavior of rubber domes, they're all fairly consistant all the way down, with some having a click in the middle.
The Cherry Cymotion Expert seems to be fairly popular around here (it's a rubber dome keyboard), but with a quick search I couldn't find any posts describing it's feel.
Offline pmyshkin
« Reply #7 on: Fri, 01 May 2009, 16:30:18 »
I just bought one of these (g81-1800 LUMUS-2). I guess I didn't do my homework because I thought they would have clicky type mechanical switches. The label on the back of the keyboard makes it sufficiently clear that these boards use MY (aka FTSC) switches, which have linear response and feel really stiff to me. It's almost impossible for me to type on this keyboard because there's no tactile or auditory feedback at all and bottoming out the keys takes more strength than I have in my fingers. There's also no USB ports, which I swear I saw advertised on one datasheet or another. Cherry's datasheets are very confusing in general. They don't clearly write out what color switches are used, just "Mechanical switches," and some versions say "FTSC membrane technology" and others don't. It almost seems like they're intentionally trying to confuse you.
It's pointless for me to return it because the place I bought it from (totalbarcode.com) has a fascist return policy.
2 redeeming qualities though - the construction is very solid and impressive, and I like the compact layout that manages to squeeze all 104 keys into a board that's 3 inches shorter than normal.
Oh well, I just hope other people don't make the same mistake as me and buy this keyboard.
Offline cchan
« Reply #8 on: Fri, 01 May 2009, 17:49:23 »
pmyshkin, Sorry you had to suffer through a Cherry FTSC keyboard. If it's any consolation, they tend to sell quite well on ebay.
HP Envy17: Core i7-2760QM, 8GB DDR3, 128GB Crucial m4 + 750GB Hitachi, Windows 7 Home Premium x64, Cherry ML4100, Logitech M500, HP zr22w
IBM Thinkpad X60: Core Duo T2400, 2GB DDR2, 128GB Samsung 830, Xubuntu 12.04 x86, Cherry ML4100, Logitech M205, HP zr22w
Raspberry Pi Model B: BCM2835, 0.25GB DDR2, 8GB Samsung SD card, Raspbian Wheezy, human interaction devices as above
Offline pmyshkin
« Reply #9 on: Fri, 01 May 2009, 19:13:28 »
cchan, thanks for listening to me gripe. Truth is, I probably got what I deserved for trying to procure a high quality product without being willing to shell out the cash or doing enough research.
I still haven't figured out why anyone would want this kind of switch on a keyboard though.
Offline cchan
« Reply #10 on: Fri, 01 May 2009, 19:18:20 »
Durability basically. It is rated for fifty million keystrokes.
And if you wanted a really nice keyboard take the g80-3000lscrc-2:
http://www.totalbarcode.com/product/Cherry_G80-3000_Standard_PC_Keyboard.html
I have one, and I love it.
Offline IBI
« Reply #11 on: Fri, 01 May 2009, 19:21:25 »
Quote from: pmyshkin;88548
Small Nitpick: There is tactile feedback, it's the keys getting stiffer as you press them down. You just don't like it.
If you've been looking at the Cherry US site then you might want to use the cherry europe site in future, as the US one does seem to be pretty poor.
http://www.cherry.co.uk/english/products/compact_keyboards_G81-1800.htm
Cherry don't use the switch colour in any official documentation as far as I know, but the do usually describe the switch type by it's feel (linear, click action, soft pressure point etc.)
Having used that layout for a year (in the form of a Raptor-Gaming K1) I didn't find myself that keen on it, for me it wasn't compact enough to make a difference over a large keyboard and it had some problems like the position of the delete key
EDIT: LSCRC is the Clicky (blue) switches, but the last two letters are usually layout (the second one is US layout with Euro key for example), so what's RC?
« Last Edit: Fri, 01 May 2009, 19:27:24 by IBI »
Offline xyzzy
« Reply #12 on: Sat, 02 May 2009, 03:35:54 »
Quote from: IBI;88581
People's Republic of China probably :)
IBM Model F62 (Ellipse's) • PFU HHKB Pro Type S Hybrid • PFU HHKB Pro • Leopold FC660C • IBM Model M SSK 1391472 • IBM Model M SSK UNI04C6 • IBM Model M 1391405 (x4) • Cherry MX 1800 Compact (blue Cherry) • Cherry MX 11900 Touchboard (brown Cherry) • Dell AT102W (black Alps) • Apple Extended Keyboard II (cream Alps) • Acer 6312-TA (black Acer) • Unikey KWD-601 (white Cherry)
Offline cchan
« Reply #13 on: Sat, 02 May 2009, 07:15:07 »
Quote from: xyzzy;88630
Nope, Republic of China, aka Taiwan.
