Author Topic: Assigning Keys  (Read 2591 times)
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
Assigning Keys
« on: Fri, 16 May 2014, 18:34:33 »
I'd like to assign my LC660C's FN-Insert and FN-Delete to be volume up and volume down respectively. What is the easiest way to do this? I wouldn't mind setting another key to mute as well.
I know this probably a newb question, sorry.
Offline BucklingSpring
Re: Assigning Keys
« Reply #1 on: Sat, 17 May 2014, 07:37:08 »
One  word answer: AutoHotKey (http://www.autohotkey.com/)
Boards I own, click ->
Offline nrd
Re: Assigning Keys
« Reply #2 on: Sat, 17 May 2014, 07:49:58 »
At least if you're on windows^^
These are my AHK mediakeys:
Code: [Select]
AppsKey & Insert::SendInput {Media_Play_Pause}
AppsKey & Delete::SendInput {Media_Prev}
AppsKey & Home::SendInput {Media_Stop}
AppsKey & End::SendInput {Media_Next}
AppsKey & PgUp::SendInput {Volume_Up}
AppsKey & PgDn::SendInput {Volume_Down}
AppsKey & Pause::SendInput {Volume_Mute}
You'd  just have to replace the "AppsKey" with your Fn key (even though it seems like it could be a bit tricky to target the Fn Key: http://www.autohotkey.net/~faqbot/faq.html#fnkey ) and mix the assigned functions around as you like. But in general it really doesn't get any easier than AutoHotKey.
Offline OnTheBrink
    • Wired In Store
Re: Assigning Keys
« Reply #3 on: Sat, 17 May 2014, 16:02:05 »
Autohotkey it is! Thanks guys ahah.
EDIT: Wait, doesn't AutoHotKey just run a script and have to remain on?
EDIT 2: I got it. I am using KeyTweaks which is really intuitive. It allows you to press the key strokes, assign a command like Volume Up and edits the registry for you. The keyboard doesn't read FN-Delete as a key so I just made it F11 and F12.
« Last Edit: Sat, 17 May 2014, 16:14:18 by OnTheBrink »
