Author Topic: Looking to buy my first mechanical keyboard  (Read 9202 times)
Offline Raddam
Re: Looking to buy my first mechanical keyboard
« Reply #50 on: Fri, 30 May 2014, 18:28:45 »
I never got the hhkb yet I just realized how much i needed the f1 keys ever since i started playing smite.
« Reply #51 on: Sat, 31 May 2014, 02:24:15 »
Personally I'd go for the RealForce, as long as it was 55g uniform.
I have a lot of experience with 45g Topre on my HHKB.
Or, if you can wait for the CM Novatouch, maybe consider that.  Conventional TKL layout with the oneness with cup rubber (Topre switches).
Offline Raddam
« Reply #52 on: Sat, 31 May 2014, 09:12:18 »
If you have 45g then why do you suggest the 55g?
Offline False_Dmitry_II
« Reply #53 on: Sat, 31 May 2014, 18:37:00 »
And, as usual, Matias switches.
http://matias.ca/products/
« Reply #54 on: Sat, 31 May 2014, 20:24:15 »
I find 45g way too light.  It is analagous to MX red, which find waaay too light.  I prefer MX blacks or greens, hence I suspect I would prefer 55g Topre.
I also like BS in my Model M :)
