Author Topic: Anyone with a Poker II have this issue?  (Read 3015 times)
Offline motoyuki
« on: Mon, 19 May 2014, 16:57:31 »
If you look closely, notice any particular gap that is wider than the rest? I'm a bit ocd so this bugs me a bit.
Offline Yslen
Re: Anyone with a Poker II have this issue?
« Reply #1 on: Mon, 19 May 2014, 17:06:10 »
If I was picking hairs I'd say my Poker II has a slightly larger gap between RT/FG/CV than anywhere else, but it's only small. Yours doesn't look too bad either.
It's certainly not exclusive to Pokers; my Ducky had a huge gap between H & J.
Offline intelli78
« Reply #2 on: Mon, 19 May 2014, 17:09:27 »
Just normal manufacturing tolerances. Not a problem.
Offline brainT
« Reply #3 on: Mon, 19 May 2014, 17:13:17 »
If it really bothers you you're welcome to send it to me  ;)
Offline motoyuki
« Reply #4 on: Mon, 19 May 2014, 17:37:42 »
Address brainT? =) ;) jk
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #5 on: Mon, 19 May 2014, 17:40:51 »
I have a Poker II. I don't think it's really noticeable unless you measure it with a ruler. Hah. But yeah, there are a few keys that looks close but it does not affect the functionality whatsoever. :)
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
« Reply #6 on: Mon, 19 May 2014, 17:41:21 »
Dejavu.. a fellow perfectionist!
Offline motoyuki
« Reply #7 on: Mon, 19 May 2014, 18:54:40 »
Hi five!
Offline motoyuki
« Reply #8 on: Mon, 19 May 2014, 19:03:29 »
Do you guys know why these variances in the gaps exist? Is there a way to fix it? Look at the gap difference between the space bar and the alt key and then the alt key and the fn key. =(
« Last Edit: Mon, 19 May 2014, 19:54:05 by motoyuki »
Offline BlueBär
« Reply #9 on: Tue, 20 May 2014, 06:07:45 »
Slight imperfections in the molds I would say, it could be variances in he plate and PCB, too, but that cannot really be fixed (and is rather unlikely). You could get a different spacebar, that might solve the "problem".
Offline mougrim
« Reply #10 on: Tue, 20 May 2014, 06:13:28 »
Perfectionists :)
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline Zeromachina
« Reply #11 on: Tue, 20 May 2014, 07:21:38 »
Just checked mine over and everything seems to be pretty well even all round. Though ... now..... i notice a little more gap between the enter and shift keys towards the rest of the alphas. And now knowing my head i'll notice it a little every day.
