Author Topic: Tenkeyless with Mac-like function buttons (media instead of F1, F2)  (Read 1431 times)
Offline dbme
Are there tenkeyless keyboards that send media keycodes (play, stop, volume up/down) instead of Fn keycodes for the topmost row of keys?
Given the way I use my computer I find myself using the media keys much more than I use the F1, F2 keys. What I am after is a tenkeyless Mac-like keyboard where pressing the first row of keys produces media actions while pressing the same buttons + fn produced F1, F2, F3. This is the opposite of what I have seen in all the keyboards I have owned.
Offline atlas3686
  • HHKB Elite
Re: Tenkeyless with Mac-like function buttons (media instead of F1, F2)
« Reply #1 on: Tue, 20 May 2014, 02:33:47 »
You can just use Keyremap4macbook to create your own shortcuts of whatever you want, for instance you could easily replace F keys with media keys. Then you can buy any TKL. Definitely the best way to go.
Offline Matias
  • * Commercial Vendor
    • http://matias.ca
« Reply #2 on: Tue, 20 May 2014, 03:13:15 »
If you're a Mac user, all of our Mac mechanical keyboards work as you described.
   http://matias.ca/products
If you're looking for something like that for Windows/Linux, you'll have to roll your own.
