Author Topic: What's your dream keyboard?  (Read 27639 times)
Offline user 18
Re: What's your dream keyboard?
« Reply #100 on: Fri, 06 June 2014, 18:12:36 »
My dream board: The one that's connected to a storage system full of other boards, so I can pick which board I want brought to me.
Hey, a guy can dream, right? :P
Avatar by ashdenej
Offline Battou62
« Reply #101 on: Thu, 19 June 2014, 10:39:44 »
I have been doing a lot of thinking on this. I think I would want a full size ASNI Filco with an Aluminum/Acrylic case, and linear switches with springs that are slightly lighter than Mx Blacks. No leds except for caps, num, and scroll locks. I have no need for programmable pcbs or anything like that. What would be the best way to achieve this?
Offline JPG
  • Model F is my new passion!
« Reply #102 on: Thu, 19 June 2014, 10:45:23 »
Buy a fullsize filco with reds/black, buy a case that you like and is compatible and buy springs that are in between reds and blacks. But you will need to desolder it all because of the plate in order to change the springs.
Else you buy a custom pcb/plate/case (like from sprit gb) and if you don't want to reprogram and put leds everywhere, you just keep the default layout and don't put more leds. You will still need to solder, get switches and all, but you will have more flexibility and ideally a plate that lets you open switches without desoldering for the time when you will want to try another type of spring or lube or whatever.
That's roughly the 2 main approaches you can have. Both with + and - and different cost.
Offline jacobolus
« Reply #103 on: Thu, 19 June 2014, 14:58:30 »
You don’t know it yet, but what you really want is green complicated Alps switches. The perfect weight, and smoother than “vintage” MX black switches. http://geekhack.org/index.php?topic=56549.0
(There are nicer linear switches, like http://deskthority.net/wiki/Honeywell_Hall_Effect or http://deskthority.net/wiki/Alps_Magnetic_Reed for instance, but they’re harder to get working with modern machines.)
« Last Edit: Thu, 19 June 2014, 15:01:18 by jacobolus »
Offline Daspartic
  • IBM is love IBM is life
« Reply #104 on: Thu, 19 June 2014, 17:30:24 »
Beam spring switches, tkl layout, stainless steel case, thick doubleshot pbt caps, and detachable usb cord.
IBM Displaywriter (82 key) | IBM Model F 4704 (107 key) |  IBM Model F AT x3 | IBM Model F XT | IBM Model F 3104 x2 | IBM 6112884 (Green Tee mount Alps) | Realforce 87u (55g) | IBM Model M 1390131 x2 | IBM Model M (1391401 '88) | Leopold FC500R (MX Browns) | Wang (725-5971) (Salmon Alps) | Acer 6011 (SKCM Blue Alps) | White Fox (65 g Zealios) | XMIT keyboard (Hall Effect)
Offline gameaholic
« Reply #105 on: Thu, 19 June 2014, 17:46:11 »
dream keyboard(s)
always changing but this is a newer thread so here's the current wish list.
Photeq's Phantom comes close.  The only thing I would change would be to give it a more rectangular case from the side like a KMAC and back lighting.
https://www.flickr.com/photos/115722906@N08/sets/72157640605854324/
couldn't find a side pic of a KMAC
1.  A cherry mx version of the IBM model M SSK.  TKL, Winkeyless, Two Tone Black on Beige GMK Cherry Profile Keycaps, Stepped Caplock.
2.  Titanium Low Profile Case like a KMAC.  Corsair RGB Backlighting.  TKL, Winkeyless, Two Tone Black on Beige GMK Cherry Profile Keycaps, Stepped Caplock.
3.  IBM SSK ANSI Model F
4.  65%?  (60% but with F row)
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline "Edgar Allen Pho is Dead."
  • formerly known as anoose
  • Member Since '11
« Reply #106 on: Thu, 19 June 2014, 19:23:52 »
This.
« Reply #107 on: Thu, 19 June 2014, 20:55:44 »
Offline Dragowing193
  • Lab Monkey
« Reply #108 on: Fri, 20 June 2014, 05:50:46 »
My dream would be a backlit TKL keyboard with a volume dial, probably rotary dial. This volume dial could be pressed down to mute or turn it to change the volume without the nasty fn+F11/12. I would prefer the volume dial to be on the right side.
« Reply #109 on: Fri, 20 June 2014, 06:03:20 »
Offline Latin00032
« Reply #110 on: Fri, 20 June 2014, 09:25:38 »
Dream keyboard
Board similar to the small fry.
But, instead of taking of f two rows to the right, only take off one row.
I don't want to rest my pinky on the enter key.
Plus, I'll have at least three more keys to make use as done of the punctuation marks.
Offline Fragil1ty
  • Abre los ojos.
« Reply #111 on: Fri, 20 June 2014, 23:33:10 »
A 75% version of the HHKB Pro 2.
e.g. A noppoo but in HHKB form.
Heaven. >;
你搞砸了
Offline Pacifist
  • on hiatus
« Reply #112 on: Fri, 20 June 2014, 23:33:46 »
I already got my dream keyboard :)) MX mini w/ full metal case :p
Offline ShawnMeg
« Reply #113 on: Sat, 21 June 2014, 00:57:19 »
« Last Edit: Tue, 26 May 2015, 18:12:18 by ShawnMeg »
IBM Model F122 X 2 internal Soarer's || IBM Model M122 internal Soarer's || AEK II SKCM Salmon ALPS external adb_usb converter ||  AEK M0115 SKCM Orange ALPS click mod external adb_usb converter || AEK M0115 SKCM Salmon ALPS external adb_usb converter ||
Offline omnigeek
« Reply #114 on: Sat, 21 June 2014, 14:56:23 »
My dream board is the one I've got: a Northgate Omnikey Ultra, rebuilt with Matias clicky switches.  The Matias switches have a great tactile touch, not too heavy or too light.  F keys on the left, Ctrl next to A and the large cursor keypad (not the inverted T layout).  And let's not forget the bigass Enter key!  Best keyboard I've ever used!
Northgate Omnikey Ultra rebuilt w/Matias clickies | Northgate Omnikey 102 | Avant Stellar | [/url]Visit the Typing Test and try!
« Reply #115 on: Sat, 21 June 2014, 18:30:36 »
Living the dream ;D
Offline 1391406
« Reply #116 on: Sat, 21 June 2014, 22:55:26 »
I already have my dream keyboard. It's a 122-key IBM Model F .
Offline Pacifist
  • on hiatus
« Reply #117 on: Sat, 21 June 2014, 22:57:47 »
I'm getting your dream keyboard on monday. Any recommendations on where to put the teensy? Internal or external?
Offline 1391406
« Reply #118 on: Sat, 21 June 2014, 23:05:23 »
It really comes down to personal choice, but I built an external variant because I liked the ease with which I can test other keyboards that use that protocol(should I ever acquire one), not to mention I like the nostalgia of having the original cable connected to the keyboard.
Offline Johan
« Reply #119 on: Mon, 30 June 2014, 12:36:10 »
I would like to try a MX-mini with ergo clears, or another type of lighter springs. It seems like a great layout. I'm not sure how the f-keys would feel though, it might really cramped resulting in tons of errors. I think I'll stick to my filco for now. I just wish the case was a bit more "sturdy"
OffTopic: Can anyone direct me to a acrylic case or a fairly cheap metal case that would fit a TKL ISO Filco?
Uh, stuff.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #120 on: Mon, 30 June 2014, 13:19:53 »
I think bueller might know where to get a cheap, decent acrylic case, so try PM'ing him. You can also look for a Vortex aluminium case, goes for around $90 in the classifieds.
Offline Pacifist
  • on hiatus
« Reply #121 on: Mon, 30 June 2014, 13:22:31 »
« Reply #122 on: Mon, 30 June 2014, 13:29:42 »
What's funny? :confused:
Offline Johan
« Reply #123 on: Mon, 30 June 2014, 14:55:07 »
I'm very confused :( Is the funny part that I decided to add "off topic" after I strayed from the subject rather than before?
« Last Edit: Mon, 30 June 2014, 15:00:09 by Johan »
Uh, stuff.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #124 on: Mon, 30 June 2014, 15:09:25 »
i don't know..............my bolt modded ssk i recently got is pretty close in my book
i know all the many customs and so on out there are pretty nice, but this thang is pretty bangin.........
ok...............i wish i had a king saver-- i said it
that, my ssk and shoot me-- i'm done :cool:
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
