Author Topic: [IC] Phantom Winkeyless+1.75x R shift Plate  (Read 3061 times)
Offline Pacifist
  • on hiatus
« on: Tue, 20 May 2014, 22:22:37 »
IC for a phantom winkeyless plate (1.5x1x1.5x7x1.5x1x1.5x) with a split R shift (1.75x1x) and the extra 5 keys above the arrow cluster
All switch holes will have notches to remove switch tops
This is my first time wanting to make a plate, so I don't know which shops are the best. Any recommendations will be appreciated
Plate will look like:
(source: jdcarpe)
but with standard spacing on the top row
* TKLPlate.svg (18.55 kB - downloaded 98 times.)
« Last Edit: Wed, 04 June 2014, 15:03:28 by Pacifist »
Re: [IC] Phantom Winkeyless+1.75x R shift Plate
« Reply #1 on: Tue, 20 May 2014, 22:29:59 »
The best shop is the one that is local to you. You will probably have to work with them on QC'ing samples, etc., so it's much easier if you're local. If you can build rapport with the guys at the shop who take your orders and actually make the plates, they can probably understand better what you want, and may be more likely to give you a break on pricing as a hobbyist. Most of these shops are dealing primarily with large commercial or industrial orders, and price their work accordingly.
Offline Pacifist
  • on hiatus
« Reply #2 on: Tue, 20 May 2014, 22:31:04 »
Ah I see. Thank you for the advice
Offline MrChunky
« Reply #3 on: Wed, 21 May 2014, 00:49:50 »
Hey pacifist, I am interested! But i have a couple of questions... Is this pretty much lightsaver layout? Does the phantom PCB have holes to accommodate this config?
« Last Edit: Wed, 21 May 2014, 00:52:03 by MrChunky »
Offline LechnerDE
« Reply #4 on: Wed, 21 May 2014, 00:55:26 »
I am interested in 2 of those plates for my 2 remaining Phantom PCBs :)
Will these be stainless steel or aluminium?
Offline Pacifist
  • on hiatus
« Reply #5 on: Wed, 21 May 2014, 01:01:43 »
Lightsaver has the extra full numpad, and it will have a gap between F# and # layer. Phantom PCB does have the holes for this
I haven't decided yet. Once I go research some shops I'll decide then
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #6 on: Thu, 22 May 2014, 11:20:30 »
Pacifist, hi.
Please, there is any chance to get one plate with that 7bit space bar?
Offline Crabby_b
« Reply #7 on: Mon, 02 June 2014, 10:06:52 »
I would be interested in one.
Offline Pacifist
  • on hiatus
« Reply #8 on: Wed, 04 June 2014, 21:30:10 »
added a svg thanks to moz
