Author Topic: Republic Commando Key Cap I Made  (Read 2025 times)
Offline BuffBen
« on: Fri, 23 May 2014, 04:46:56 »
Link = https://www.shapeways.com/model/1996914/republic-commando.html?li=my-models&materialId=6
Im not charging anything for the model or marking up any of the prices. If you do decide to buy it post a picture of it so i can see how well it comes out. Thanks.
I didnt put in the full helmet because i thought it would make the key too big.
But if you guys want a version of it where the entire top of the key is just the republic commando i can do that.
« Last Edit: Fri, 23 May 2014, 05:04:28 by BuffBen »
Offline Hyde
  • White Tofu Extraordinaire
Re: Republic Commando Key Cap I Made
« Reply #1 on: Fri, 23 May 2014, 08:48:41 »
From the key angle I think you used a profile from the Z, X, C, V........ etc row.  Might be better if you use the profile from Esc, F1, F2..... etc row.
If you don't know what I mean by profile, refer to this:  http://keycapsdirect.com/images/key-caps/angle3.jpg
But yeah it's just because people typically display their novelty keycaps on the top row.  Hope this helps.  :)
Offline BuffBen
« Reply #2 on: Fri, 23 May 2014, 13:28:24 »
Unfortunately that key cap is the only base model i have (atm) Its designed to the correct proportions so i can just open it up in 3ds or Maya and start putting my models on the tip of the key cap.
