Author Topic: Where to find Japanese layout keyboards?  (Read 1330 times)
Offline roaming pear
  • THE Roaming Pear
« on: Fri, 23 May 2014, 06:53:51 »
Hello.. I was wondering where a good place to find Japanese layout keyboards would be (outside of Japan if possible).  Used might be better for my purposes.
« Last Edit: Fri, 23 May 2014, 07:14:56 by roaming pear »
Does anyone have any accessories or key caps or other poker 2 related things lying around that they are not using?  I don't mind taking it off your hands if you no longer want it...
Offline epzy
  • HHKB Fiend
  • ded
Re: Where to find Japanese layout keyboards?
« Reply #1 on: Fri, 23 May 2014, 06:55:20 »
Amazon.co.jp at least.
Offline Smasher816
  • HHKB Master
« Reply #2 on: Fri, 23 May 2014, 11:57:51 »
That is probably the easiest way to find lots of Japanese keyboards. If you do go that route you will probably need a proxy (such as Tenso) since not too many companies want to ship internationally from Japan.
Offline Tarzan
  • formerly known as Greystoke
« Reply #3 on: Fri, 23 May 2014, 12:01:32 »
I think there's at least one Japanese layout keyboard in the Classifieds at the moment.
http://geekhack.org/index.php?topic=58507.msg1336249#msg1336249
