Author Topic: how do i open a razer bw tkl cherry edi  (Read 1756 times)
Offline frosty
  • jukebox hero
« on: Fri, 23 May 2014, 11:12:48 »
title says it all! help me please! :(
Offline Defect
Re: how do i open a razer bw tkl cherry edi
« Reply #1 on: Fri, 23 May 2014, 12:08:52 »
For most keyboard you start with unscrewing the case.
Usually means 4 or 5 screws on the bottom of the case, often 1 screw will be covered or hidden (usually with a warranty sticker or even under the rubber feet in very rare instances)
Offline jonathanyu
« Reply #2 on: Fri, 23 May 2014, 13:00:33 »
iirc, there is no screw under the razer lable, and there are screws under the rubber feet.  And the plastic of the case is very weak, so don't pull it very hard, otherwise it will break. I have broken mine in the past
Offline Pacifist
  • on hiatus
« Reply #3 on: Fri, 23 May 2014, 13:02:53 »
1. Get a hammer case
2. Hit the razer keyboard (focus on crap case and caps)
3. Buy a new board
4. Put it in the hammer case
Offline Defect
« Reply #4 on: Fri, 23 May 2014, 14:05:05 »
3. Buy a new board
Tbh I'd just do steps 2 and 3.  Then 4 with a sandwich of sorts.
Offline frosty
  • jukebox hero
« Reply #5 on: Sat, 24 May 2014, 02:02:11 »
3. Buy a new board
just wanted to desolder the switches for future use :P
Offline Moosecraft
  • HHKB Pro
« Reply #6 on: Sat, 24 May 2014, 02:11:53 »
The screws are under the rubber feet on the back.
Offline Pacifist
  • on hiatus
« Reply #7 on: Sat, 24 May 2014, 02:19:05 »
3. Buy a new board
That's why you focus on the crap case and caps, the only things a reasonable person never wants to see again.
Offline frosty
  • jukebox hero
« Reply #8 on: Sat, 24 May 2014, 02:32:33 »
got it. razer's pcb is...
unusual.
