Author Topic: Purple on White  (Read 3777 times)
Offline Blackehart
Purple on White
« on: Fri, 23 May 2014, 17:14:13 »
Is there a Purple on White key set?
EDIT: or White on Purple
Was the GMK White on Purple just the modifiers?
Purple Drank addicts would like to know.
-Blacke
« Last Edit: Fri, 23 May 2014, 18:35:15 by Blackehart »
Re: Purple on White
« Reply #1 on: Fri, 23 May 2014, 18:57:16 »
No set only modifiers
Offline HPE1000
  • Keycap Paparazzo
Re: Purple on White
« Reply #2 on: Fri, 23 May 2014, 19:02:00 »
There were those white on purple dsa keycaps on massdrop if I remember correctly.
Re: Purple on White
« Reply #3 on: Fri, 23 May 2014, 19:03:56 »
That didn't go anywhere did it?
Offline HPE1000
  • Keycap Paparazzo
Re: Purple on White
« Reply #4 on: Fri, 23 May 2014, 19:04:42 »
Doesn't look like it
Offline Latin00032
Re: Purple on White
« Reply #5 on: Fri, 23 May 2014, 19:23:01 »
I put a post to Ivan before.
He did hint at liking the idea of purple type key set. (I think it was black on purple)
To be clear, he didn't say he was going to do one. But, he was interested. So, there is always hope for a new purple-like type gmk key set in the future.
« Last Edit: Fri, 23 May 2014, 19:24:38 by Latin00032 »
Re: Purple on White
« Reply #6 on: Sat, 24 May 2014, 02:49:50 »
Offline Blackehart
Re: Purple on White
« Reply #7 on: Sat, 24 May 2014, 09:29:45 »
Purple with clear legends: http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=229
I have those.
Those are more on the lavender side. The legend is almost impossible to see without a back light. It's not a lush, pimp suit purple.
Offline jonathanyu
Re: Purple on White
« Reply #8 on: Sat, 24 May 2014, 15:39:16 »
Lily set is purple on white, but mods is white on purple.
GMK white on purple is just the mods
Re: Purple on White
« Reply #9 on: Sat, 24 May 2014, 20:30:27 »
Maybe start petitioning someone to do a full purple/white GB.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Purple on White
« Reply #10 on: Sat, 24 May 2014, 22:26:35 »
I've ran many other color in dyesub buys. Perhaps purple on white key would be a good one for next time. At least with dyesubs we don't have the trouble of making a high number. Since only the printing it's easy to do as little as 20. I will keep in mind.
« Last Edit: Sat, 24 May 2014, 22:28:20 by IvanIvanovich »
Offline Blackehart
Re: Purple on White
« Reply #11 on: Sun, 25 May 2014, 02:31:00 »
 :-* 8) ;D
Offline Mr. D
Re: Purple on White
« Reply #12 on: Mon, 26 May 2014, 21:51:38 »
I'd absolutely buy a purple on white PBT set.  Very nearly bought the Lily set but was turned off by the ABS.
QFR | Model M | AT101W
Offline Danule
Re: Purple on White
« Reply #13 on: Sun, 01 June 2014, 09:48:15 »
We need more purple!
45g Brown Brown Blue
Offline CaptLock
Re: Purple on White
« Reply #14 on: Sun, 01 June 2014, 10:31:33 »
Offline RESPRiT
  • HHKB = ❤
Re: Purple on White
« Reply #15 on: Mon, 02 June 2014, 12:03:22 »
Well, there's the GB for purple switch covers at least :P
