Author Topic: Keyboard Talk of the Day (KTOD) - Typing Bad Habits?  (Read 12036 times)
Offline YummyTreeSap
Re: Keyboard Talk of the Day (KTOD) - Typing Bad Habits?
« Reply #50 on: Fri, 30 May 2014, 10:49:48 »
Wait, you're supposed to hit the C with your middle finger? I guess that's my bad habit then too, even though I beg to differ. It's approximately the most uncomfortable thing in the world to attempt hitting the C with my middle finger. Yuck.
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
« Reply #51 on: Fri, 30 May 2014, 11:12:53 »
- I don't use my pinkie enough.
- I need to learn symbol locations better. Both on number row and with right pinkie.
- I need work on using functions quicker with my FC660C
- Much better with using CTRL in the Caps Lock position (love it so much) but still mess up a bit. Shouldn't be long for muscle memory to completely settle in.
Offline Mr. D
« Reply #52 on: Fri, 30 May 2014, 11:17:11 »
Reading through this thread has made me realize I have all kinds of bad habits I didn't even know were bad habits.  Got more to fix than I thought.
QFR | Model M | AT101W
Offline Premonition
  • HHKB Elite
« Reply #53 on: Fri, 30 May 2014, 12:24:54 »
Hitting the space bar with my right Index.  Some idiots started doing it on Youtube and now they've got me doing it... :(
I think you're supposed to do that, because you use your left hand more.
Offline tribade
« Reply #54 on: Fri, 30 May 2014, 12:33:56 »
Proper typing has been pretty well hammered into my brain, except for my wrist position and the fact that I ALWAYS bottom out.  I don't usually find that bottoming out is a problem, though.  For me it's actually enjoyable.  Probably why I enjoy Topre switches so much, to be honest.
KMAC mini w/ blacks | Realforce 87uw 55g w/ Digil0g case | KMAC w/ blacks | Duck Viper w/ clears
"Te occidere possunt sed te edere non possunt nefas est."
Offline zflamewing
« Reply #55 on: Fri, 30 May 2014, 12:48:06 »
I normally do the following:
  • bottom out, less so with greens, though it's can be pretty often too.
  • Mostly use the first few fingers on each hand.
  • Use my ring fingers for the keys that are on the edges of the alpha keys and modifiers.
  • Left thumb the space bar exclusively.
  • Almost exclusively use the:
    • right shift.
    • left ctrl.
    • left alt.
I wonder how challenging my jump to the ErgoDox will be once I get mine built.
-edited for clarity on a few points.
« Last Edit: Fri, 30 May 2014, 19:08:19 by zflamewing »
DK9008 MX Blues | CM QFR MX Blues | CM XT MX Greens
« Reply #56 on: Fri, 30 May 2014, 15:33:15 »
No way you're supposed to hit the spacebar with your right *index finger*. Maybe your right *thumb*.
Offline Premonition
  • HHKB Elite
« Reply #57 on: Sun, 01 June 2014, 11:14:24 »
Why is bottoming out bad? I can understand it being bad if it causes discomfort, but I have been bottoming out since I have first been on computers and I can type just fine.
A bad habit of mine though is that I don't alternate thumbs depending on which hand finished the word I just typed - I almost exclusively use my left thumb so my right thumb just kind of hangs there uselessly.
Bottoming out makes you a little bit slower because of the extra distance and force used.
Offline moukimokyu
« Reply #58 on: Tue, 03 June 2014, 10:40:00 »
Left shift forever. Same with left Ctrl/Alt/Win too. Found myself staring at my right shift key the other day wondering why it was so big since I never use it  :confused:
It probably has a lot to do with the fact my left hand stays pretty much stationary but my right hand likes to dance all over the place. And I always hit the space bar with right thumb.
Also I have this habit of holding down left shift to write capslocky things instead of using Capslock - I never saw it as particularly bad but my best friend pointed out how weird it was once. I didn't do it as much after that...
Offline jterp7
    • good typing
« Reply #59 on: Tue, 17 June 2014, 14:44:34 »
yeah...i got 90wpm yesterday (good typing test) on the dell membrane at work without even trying vs at best 80 on my qfr brown.
Offline divito
« Reply #60 on: Tue, 17 June 2014, 15:38:11 »
- My typing style is weird, using primarily only my index and middle finger for both hands, with the ring fingers sporadically thrown in there. This limits my WPM to ~80-120 depending on the test/application.
- I always bottom out, though I'd argue that this isn't really a bad habit. I think typing without bottoming out is just plain weird.
- I only use right shift for question marks. That being said, I don't really use any of the right modifiers.
- As careful as I am when eating/drinking around my keyboard, keeping this stuff in the vicinity and on my desk is definitely a bad habit.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline fknraiden
« Reply #61 on: Tue, 17 June 2014, 15:52:09 »
I just thought of something else. If I took a class on typing for two years and I still have bad habits, that made me a bad student right?
Or am I just living up to my user name?
You always live up to your username
Offline jacobolus
« Reply #62 on: Tue, 17 June 2014, 17:17:15 »
My bad habits?  [...]- I use my left index finger to hit "Y". I think you're supposed to use your right index finger?
Just balance it out by typing "T" with your right index finger.
« Reply #63 on: Tue, 17 June 2014, 17:20:58 »
I already do that :(
Offline jacobolus
« Reply #64 on: Tue, 17 June 2014, 17:21:39 »
I have one more though, I tend to press the c with my index finger instead of my middle finger, also been working on that.
This sounds like an ergonomic improvement over the “standard” approach.
I advocate typing approximately like this:
(Well actually I advocate getting a new keyboard with a better physical layout, and a new character map better than QWERTY.. but if you’re going to be stuck on standard equipment, might as well make the most of it.)
« Reply #65 on: Tue, 17 June 2014, 18:50:02 »
Someone actually created a custom keycap set with different colours for each finger.  We wondered at such an unusual layout, but ot made perfect sense when it was explained.
