Author Topic: What should I get for my first mechanical keyboard?  (Read 4357 times)
Offline tytl
« on: Thu, 29 May 2014, 18:10:03 »
Hi all,
I am currently looking for a new mechanical keyboard to replace my dell keyboard. I think my only requirements are that it has to have the num pad and Cherry MX brown. I don't really care about backlight and macro keys.
Are there any good keyboards that you guys can recomend? Budget is $170 (I can throw in more if it's really worth it).
« Last Edit: Thu, 29 May 2014, 19:53:28 by tytl »
Re: What should I get for my first mechanical keyboard?
« Reply #1 on: Thu, 29 May 2014, 18:15:55 »
Welcome to Geekhack!
Filco?
Ducky?  Ducky Shine if you want backlighting.
Offline Defect
« Reply #2 on: Thu, 29 May 2014, 19:20:55 »
If you say "budget is no problem" people will start recommending Korean custom boards with aluminium cases.
If budget is no problem but you wanna save money, QFR boards can be found around 60 when on sale.  Good value for money.
60% boards are nice, too.  Personally prefer those.
Offline strict
  • TKL Zealot
« Reply #3 on: Thu, 29 May 2014, 19:27:27 »
Get a Filco, I promise you will not regret it. The build quality is excellent and it's plate mounted with costar stabs so it will type like a dream. It sounds like the model you would want is FKBN104M/EB2 .
Offline tytl
« Reply #4 on: Thu, 29 May 2014, 19:54:25 »
Ok, I've thrown in a budget in my fist post.
I'll take a look at Filco and Ducky.
What's QFR boards?
Offline Defect
« Reply #5 on: Thu, 29 May 2014, 19:58:19 »
What's QFR boards?
For 170 budget I'd recommend Filco.  If you like backlighting I'd recommend Ducky Shine III, or anything Ducky.
If you want to try a gaming-friendly layout, look for Keycool 84's and Choc Mini's.
If you want the aesthetics of a 60%, Poker II.
QFR = CoolerMaster Quickfire Rapid.  The cheap version of a Majestouch 2, but still really good quality.
Offline Firebolt1914
  • POM Overlord
« Reply #6 on: Thu, 29 May 2014, 19:58:40 »
QFR is Cooler Master's QuickFire Rapid. Here is a link: http://www.coolermaster-usa.com/product.php?product_id=3060
« Reply #7 on: Thu, 29 May 2014, 20:02:50 »
OP says must have numpad :p
Filco.
  • POM Overlord
« Reply #8 on: Thu, 29 May 2014, 20:06:45 »
It was just that the OP was wondering what QFR was. I also got ninja'd by Defect  ^-^
Offline strict
  • TKL Zealot
« Reply #9 on: Thu, 29 May 2014, 20:51:03 »
One of the biggest complaints I have against the CM boards are the cheap PCBs. If you ever plan on desoldering switches to swap them out or to install a aftermarket plate you have a much greater chance of ****ing something up on a CM single sided PCB as compared to a higher quality, double-sided PCB like a Filco would have. Also, that awful rubber coating on their boards is a dirt magnet and looks like ass when it wears off in some spots and not others.
IMO, Filco boards really are worth the extra money if you can afford it.
Offline minho
  • i'm kind of back
« Reply #10 on: Thu, 29 May 2014, 21:21:41 »
Many people don't ever bother doing any mods to their keyboards that would involve desoldering, so this is a non-issue for most. I can't speak against the rubber casing though.
Also OP, check out the Quickfire TK - keyboard with a numpad with the size of a TKL board. Be warned that it has nonstandard modifiers though, so if you ever want to replace all of your keycaps, you will have a little more trouble finding a set that will fit your modifiers/spacebar.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #11 on: Thu, 29 May 2014, 21:26:50 »
I'd say Ducky as I have good experiences with it. It has backlight but it can be switched off if you don't fancy it. But if you're certain that you would not want backlight then filco would be a good choice. Qfr is alright from what I heard. :D but I defo recommend ducky if you're going that path.
« Reply #12 on: Thu, 29 May 2014, 21:36:07 »
Can always get a Ducky Zero - no backlighting :)
Offline Mr. D
« Reply #13 on: Thu, 29 May 2014, 21:55:33 »
As someone who was initially looking a full size boards only, I'd suggest considering a tenkeyless board in conjunction with a separate number pad.  That way you get the best of both worlds (plus it seems like there's a greater choice of smaller boards vs. full size ones).
QFR | Model M | AT101W
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #14 on: Fri, 30 May 2014, 23:00:38 »
Ah the zero series. Thing is unlike the shine series, the cables are not detachable. Some might like it some might not. Personally I prefer my cables to be detachable. :D
And the zero series are manufactured in China, (Shine is Taiwan). Not sure if it makes any difference quality wise. *OP - come to the ducky side, we haz cookiez.  :p
Offline esoomenona
  • Gnillort?
« Reply #15 on: Fri, 30 May 2014, 23:07:17 »
Daskeyboard 4
Offline suby4me
« Reply #16 on: Fri, 30 May 2014, 23:29:14 »
Daskeyboard 4
I actually second that too ;)
current: poker 2 | HHKB pro2, Novatouch | off: das keyboard 4 | Ducky 3 TKL | death by coffee das keyboard mac ver. | razer blackwidow | whitefox | corsair K70 RGB
« Reply #17 on: Sat, 31 May 2014, 02:27:43 »
Well regarded Filco has non-detachable cables :p
For some it would be a plus - no mini USB plug to work its way loose.
Offline johndavis33
« Reply #18 on: Sat, 31 May 2014, 08:07:01 »
Ducky Preimer or the 9008 pros. Really any ducky with dye sub PBT. About the same price as a Filco, but the caps are leagues ahead of it.
HAVE AND WILL KEEP: HHKB - Printed white | Ducky Banana edition - Whites | Model M13 | Unidentified Goodwill keyboard - Simplified black ALPS
TOO BE SOLD: TG3 BL82 - Clears | Wheelwrite 5 - Buckling Springs typewriter
SOLD: Rosewill RK9000 - Blacks | QFR - Blues | Ducky G2 Pro - Greens |
IT WILL BE MINE: Northgate Omnikey - White ALPS
Offline tytl
« Reply #19 on: Mon, 02 June 2014, 14:07:46 »
Thank you everyone for the recommendations.
I think I'm going to get the Ducky Shine 3. I have to wait for my local retail store to get more stock, so in the meantime, I'm still open to suggestions.
Offline D01
« Reply #20 on: Mon, 02 June 2014, 14:31:20 »
WASD is what I'd suggest for a no frills full size.  In your price range, customizable, and slightly better key caps than Filco imho.
Offline RESPRiT
  • HHKB = ❤
« Reply #21 on: Tue, 03 June 2014, 08:35:07 »
I would ONLY recommend WASD for the customization and nothing else. It gets outclassed in pretty much all other fields as far as value goes and even if customization is something OP wants, the thrill of the gimmick can wear off after the initial "oh cool it's not normal!" goes away.
Offline D01
« Reply #22 on: Tue, 03 June 2014, 08:56:49 »
Well I own both a Filco and two WASD's.  The WASD's are better.  Don't own a Ducky or a Das so can't comment.
