Author Topic: swill's build log - Sprit PCBs  (Read 285707 times)
Offline swill
  • builder & enabler
    • swillkb.com
Re: swill's build log - Sprit PCBs
« Reply #50 on: Wed, 09 July 2014, 14:42:20 »
I found this thread helpful when doing SMD soldering for my ErgoDox. :thumb:
Cool, thats nice to hear.  I have learned a lot in this process.  This second (bigger) board took me about 1/2 as much time as the first one took to get all the SMD stuff soldered on.
Offline limitz
  • "the old gods stir and will not let me sleep..."
« Reply #51 on: Sun, 13 July 2014, 01:49:29 »
I'm interested in a 75% SpiRiT, however, I'm a bit confused to as how everything fits together.
There are 3 pieces that make up the case, and 1 piece that makes the plate. Does this mean that the plate is optional, and only necessary if I wanted to plate mount, instead of PCB mount the switches?
May seem like a dumb question, but I'm just trying to visualize how this will look in the end.
Thanks.
Mmm... machined aluminum
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #52 on: Sun, 13 July 2014, 06:48:36 »
Thanks.
Unfortunately I am not going to be any help on this. I did not buu any of his cases since I am prototyping and building my own case design. Sorry.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #53 on: Sun, 13 July 2014, 21:53:00 »
"My keyboards bring all the geeks to the yard,
And they're like
It's better than ours,
Damn right it's better than yours,
I can teach you,
But I have to charge"...  :P
Switches are finally together.  Just I just have to solder it all up and build a case...
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #54 on: Sat, 19 July 2014, 05:55:13 »
The PCBs' Quality is  OK?
I am Not  sure what Members feel    ::) ::)
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #55 on: Sat, 19 July 2014, 09:34:52 »
Yes. The pcb quality is excellent. :)
Offline Cottonsox
« Reply #56 on: Sat, 19 July 2014, 09:45:54 »
I just read your tip on inserting the sip sockets using tweezers.
Did you by chance try using a LED?
I found it quiet easy to attach both sockets to an led and slip it in, then used a small flathead screwdriver 2.4mm I think it was, inbetween then led wires to dislodge them inside the switch.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #57 on: Sat, 19 July 2014, 10:29:29 »
That process sounds long to me. The sockets will move around a bit after you insert them anyway, so I am not sure if there is an advantage to that. How did it work out for you?
Offline Cottonsox
« Reply #58 on: Sat, 19 July 2014, 10:35:33 »
Didn't really take long, was a smooth process for me, I found it more annoying to put my snipped led's in after I closed the switches in preparation for soldering.
Each time you place them in, you place both sockets, so for me I think it saved time for any other alternatives.
I don't own any small tweezers that would work for me, so mothing to compare to.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #59 on: Sat, 19 July 2014, 10:52:14 »
I don't own any small tweezers that would work for me, so nothing to compare to.
Ya. I needed to find something that would help me place them because they are small and annoying to work with. These tweezers worked will, but they are just what I had in front of me.
It's all about finding solutions with what you have on hand. :). Good job.
Offline bakteria
« Reply #60 on: Mon, 28 July 2014, 03:24:35 »
How did you use that battery as a led tester? I got a 2032 3v flat battery and cant get my leds to light up.
SS 7G black - Pure red - poker blue (MKC Tray)
« Reply #61 on: Mon, 28 July 2014, 04:39:56 »
If it's a high Vf LED (blue or white are usually over 3V) the battery might not have enough voltage to deliver current to the LED sufficient to light it to visible brightness.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #62 on: Mon, 28 July 2014, 09:07:57 »
Make sure you are using it the correct way. It will work one way0 and if you rotate it, it won't work (due to the polarity of the led).
I have tested white, blue, etc, and they all light up fine with 3V.
Offline bakteria
« Reply #63 on: Mon, 28 July 2014, 10:04:55 »
Could have sworn I tried both ways. Of course it started working with your tips. :)
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #64 on: Mon, 28 July 2014, 10:15:37 »
I did the same thing.  :)
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #65 on: Sun, 03 August 2014, 22:37:56 »
Final push on the 75%.  It is all built and feeling great.  OP has been updated...
Teaser...
73295-0 73297-1 73299-2 73301-3
« Reply #66 on: Mon, 04 August 2014, 01:21:27 »
I do enjoy the "simple case" design.
Offline Lubed Up Slug
« Reply #67 on: Sat, 09 August 2014, 10:05:05 »
Where did you get those PIP sockets?
« Reply #68 on: Sat, 09 August 2014, 19:25:45 »
If it's any help, I got mine from eBay (this listing, I believe) and they worked quite well.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #69 on: Sat, 09 August 2014, 20:46:33 »
I bought mine from here: http://www.ebay.com/itm/3PCS-Strip-Tin-PCB-Female-IC-Breakable-40pin-Single-Row-Round-Header-Socket-/200924888625?ssPageName=ADME:L:OC:CA:3160
They took about a month to arrive though.  If you are in the US, I think dorkvader's link is probably better.  If a couple dollars is worth waiting a month for, then go ahead and get them from where I got mine.  I bought a ton of them (basically enough to do like 6 keyboards) and I knew that the components for my builds where about a month or two off when I ordered, so I was not worried about the shipping delay.
Offline jaime
« Reply #70 on: Tue, 26 August 2014, 14:09:31 »
Hello,
I am interested in building this as well.
Would you be able to list your BOM for this? I am thinking that I only need to order the PCB and switches for this, am I close?
Thank you,
Jaime
Offline christkind
« Reply #71 on: Fri, 08 May 2015, 15:28:48 »
Sorry for digging up this topic, but since more and more people are getting their stuff from sprit...
Thanks for the amazing build log, the tweezers and diode tip is so great, was really intimidated by the size of the diodes but thanks to this guide it was pretty straight forward :)
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #72 on: Thu, 14 May 2015, 11:15:36 »
No worries.  :)  I actually have a new Sprit 75% board to solder up, so I will probably be adding a third entry here soon.  Ya, of everything I learned, that is by far the most useful.  I doubt I will have any new tips on my third board, but I will try to add it anyway.  Glad it was helpful.  :)
