Author Topic: Having problems with my Ducky Shine 3  (Read 3017 times)
Offline markexodia
« on: Mon, 02 June 2014, 19:28:03 »
I don't know whether is it correct to post here or not but heres my issue.
Some keys are on with dim light..  even with my LED mode off.. some leds of mine are still light up but it's dim.. any idea guys? tried totally offing it and changing usb ports. Still the same... Only been using it for 2 months....
Offline Firebolt1914
  • POM Overlord
Re: Having problems with my Ducky Shine 3
« Reply #1 on: Mon, 02 June 2014, 20:10:43 »
Which keys are they; also can you post a picture if possible?
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #2 on: Mon, 02 June 2014, 20:21:20 »
With the newest firmware, F11 and F12 are you're user configurable leds.
Press either till they go bright again and then you can cycle through the main modes.
Or Press and hold Fn+F10 to turn them all off and turn it on again.
If you ever need to reset it, hold both winkeys at the same time, it will reset the whole board.
Good luck! :p
Offline markexodia
« Reply #3 on: Tue, 03 June 2014, 02:12:53 »
Here is a picture of it
Offline markexodia
« Reply #4 on: Tue, 03 June 2014, 02:13:30 »
Good luck! :p
i tried resetting.. but it didn't work..  :(
Offline C5Allroad
« Reply #5 on: Tue, 03 June 2014, 05:05:16 »
Good luck! :p
What version firmware are you on?
« Reply #6 on: Tue, 03 June 2014, 05:42:43 »
It seems odd that it is a few alternate keys in one row - like is there a short on the PCB maybe?
If this is still under warranty, and no-one can think of anything that will probably turn out to be blindingly obvious, can you RMA it?
  • POM Overlord
« Reply #7 on: Tue, 03 June 2014, 19:04:00 »
Try pressing the fn/menu key and print screen, then pressing the keys that are still on. I'm pretty sure it's a hardware issue, but it's worth a shot.
Offline markexodia
« Reply #8 on: Wed, 04 June 2014, 01:59:40 »
Good luck! :p
Latest Firmware
Offline markexodia
« Reply #9 on: Wed, 04 June 2014, 03:25:05 »
i tried contacting my supplier already, he said might be the firmware issue....
Offline markexodia
« Reply #10 on: Wed, 04 June 2014, 03:28:36 »
i tried to off all the LED but the led is still light up dim, even in off
« Reply #11 on: Wed, 04 June 2014, 05:18:35 »
Firmware is upgradeable.  If you are sure you are running the latest version, then there is nothing else that you can do to the firmware.
My Shine 3 does not exhibit this, but I have not idea what firmware it is running.  I can turn all LEDs on, or all LEDs off (or any of the intermediate flashing modes).
Offline C5Allroad
« Reply #12 on: Wed, 04 June 2014, 05:19:14 »
You say the led as if it is just one. Could this be the space bar?
If not, what key is it?
