Author Topic: IBM Model M loose ground wire  (Read 5677 times)
Offline gustavQ
« on: Tue, 03 June 2014, 17:06:40 »
Hi everyone.
Sorry if i'm open a new topic just to ask, what I think is, a quick tip.
So, I was disassemble a model M and, I don't know if it was me, but I found a ground wire loose from the board.
I want to put it back in the right place, but I don't know where.
I took a picture to make it easy to show the problem.
Can someone show me the correct spot to re-solder the wire?
Thanks
Offline E TwentyNine
    • Some of My Keyboards
Re: IBM Model M loose ground wire
« Reply #1 on: Tue, 03 June 2014, 17:15:24 »
J6.   No soldering, it should have a slide connector.
Similar to this
Offline gustavQ
« Reply #2 on: Tue, 03 June 2014, 17:39:48 »
The ground wire with the connector is also there, but not in the picture. I have two ground wires, but one is loose. The board of my keyboard appears to be a little bit primitive compared to that one.
« Reply #3 on: Tue, 03 June 2014, 17:50:22 »
The other ground wire goes to the cable.  Check the cable for a broken wire.
Offline gustavQ
« Reply #4 on: Tue, 03 June 2014, 18:10:46 »
Sorry, but i'm not following you.
In this picture you can see that they are two separated ground wires.
« Reply #5 on: Tue, 03 June 2014, 18:41:14 »
the one with the connector goes to the tab on the PCB. The other one sholud go to the cable, I think.
What M is it, specifically? (A lexmark?) I don't think I have one that new or I'd crack it open and check.
« Reply #6 on: Tue, 03 June 2014, 19:37:31 »
There's a couple of pictures here of my cable while I was refurbishing a Model M (actually I ended up making a replacement fixed PS/2 cable for it).
Offline 0100010
  • Not Sure
« Reply #7 on: Tue, 03 June 2014, 20:03:35 »
The thin black wire is part of the cable, the thick black wires spade connector goes to the end of J6.
« Reply #8 on: Tue, 03 June 2014, 20:39:41 »
It will probably still work without the ground wire attached to the cable, but it probably won't be FCC part15 compliant though.
Offline gustavQ
« Reply #9 on: Wed, 04 June 2014, 03:37:19 »
Yes, is a Lexmark:
You are all right it is from the cable, I needed to strip a little bit of the cable to see the other end of the wire.
I'm going to fix this.
« Reply #10 on: Wed, 04 June 2014, 05:37:45 »
Having stripped the cable, you've lost the strain relief that the gromit was providing.
Depending on your location, budget etc. you might consider replacing the cable.
Unicomp sell them for $15 - but maybe get someone else to confirm that this is the correct cable as there is no picture.
Offline gustavQ
« Reply #11 on: Wed, 04 June 2014, 06:49:39 »
When I was offered the keyboard the strain relief was already broken thats why I stripped the cable.
I'm going to do the PS/2 to USB mod anyway. I'm waiting for the material to do that, and in the meantime, I want to to check if the Keyboard is fully funcional. But I don't have the PS/2 to USB converter yet.
