Author Topic: KTOD - Switch Comparisons  (Read 1972 times)
« on: Thu, 05 June 2014, 13:22:35 »
I've been talking to some users through PMs about Alps switches. I'd like to write down and share my experiences with them soon but I thought it might be a fun discussion to have here. Do you always compare switches to MX? Do you have a baseline?
How do you test and quantify switches you've never tried before?
I think it's hard to say that an MX Black is like a complicated linear Green Alps is like a Honeywell Hall Effect switch. Sure they're all linear switches but they're different to me. Same thing with a comparison of complicated Blue Alps to MX Blues to Buckling Springs.
But I do still use MX as a baseline if I have to.
« Last Edit: Thu, 05 June 2014, 13:26:01 by CPTBadAss »
Offline Defect
Re: KTOD - Switch Comparisons
« Reply #1 on: Thu, 05 June 2014, 14:52:04 »
I look at
Actuation/Release point
Key stability/wobble
Travel distance
Bottom out feel
Weight (stock, excluding spring mods)
Type of click or tactile bump (crisp vs rounded,  smooth or grainy)
Sound
Think of more later
« Reply #2 on: Thu, 05 June 2014, 15:26:42 »
I just 1a2a3a6e6e6e634513426e634543a4a5a6e6e6345
and if it feels nice after doing so for an hour or so then it's good
« Reply #3 on: Thu, 05 June 2014, 15:27:23 »
Is that the official DT-35 testing method?
Offline Firebolt1914
  • POM Overlord
« Reply #4 on: Thu, 05 June 2014, 15:36:11 »
In my opinion, you can't quantify some things. There are lots of variables that influence what you think about things that have to do with 'feel'.
« Reply #5 on: Thu, 05 June 2014, 15:37:59 »
So how did you pick a keyboard? And how do you pick the second keyboard after that?
Offline Defect
« Reply #6 on: Thu, 05 June 2014, 16:20:03 »
For physical testing I have 2 Data911s I bought for 25 shipped each.  Testing an offline keyboard is way different from having real time live feedback on screen, especially noticible with clear springs as they are heavy to bottom out but surprisingly easy to actuate and cushiony.  I do this for testing MX stem/spring combos.
Also I change maybe monthly the F-Rows on my Shine II that I bring to work.  So I can spam keys when no one's looking and figure out what I want for my next board.
Testing alps is something we've talked about and something I want to get into.  I plan on using this same method.  Buy a bunch of switches and swap and solder.
  • POM Overlord
« Reply #7 on: Thu, 05 June 2014, 16:27:10 »
I guess what I do is find something that sounds like I would like it, and just buy it. If I don't really like it, i'll sell it or trade it.
Offline Moosecraft
  • HHKB Pro
« Reply #8 on: Thu, 05 June 2014, 17:45:40 »
Buy them and test them out.
