Author Topic: PMK Login Issue  (Read 110767 times)
Offline Excessive
  • Signature Plastics
  • * Moderator
PMK Login Issue
« on: Fri, 06 June 2014, 09:15:14 »
Hey everyone sorry for the login problems. We updated the checkout process and it has caused a shipping address issue with a small select group of accounts. I am working on fixing these but need a little more information.
If you are having this problem, would you please send me a PM with the following information:
PMK Username
PMK Email Address
Default Shipping Address
Re: PMK Login Issue
« Reply #1 on: Fri, 06 June 2014, 10:03:56 »
Thanks Excessive!
My login issues are fixed (for now :P)! ;)
Offline DanielT
Re: PMK Login Issue
« Reply #2 on: Fri, 06 June 2014, 12:46:56 »
Sent PM
Offline Oobly
Re: PMK Login Issue
« Reply #3 on: Thu, 28 August 2014, 04:55:31 »
Hi,
I'm having trouble logging in. When I tried with what I'm pretty sure my password is, it didn't work. When I use the "forgot my password" link, the email never arrives to my email address.
So I currently have no way of logging in to add items to my Group Buy order. Please advise.
Best Regards,
Oobly.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Oobly
Re: PMK Login Issue
« Reply #4 on: Mon, 01 September 2014, 02:12:06 »
Sorted out!
Thank you, Excessive!
Offline Synjin
Re: PMK Login Issue
« Reply #5 on: Thu, 11 September 2014, 23:41:22 »
I am having troubles logging in. The only way I can log in is to constantly reset my password every single time I want to access my account
Re: PMK Login Issue
« Reply #6 on: Fri, 12 September 2014, 08:38:31 »
PM Excessive he can sort you out.
Offline Synjin
Re: PMK Login Issue
« Reply #7 on: Fri, 12 September 2014, 11:05:40 »
I actually did message him already. I'm just waiting for him to reply.
Re: PMK Login Issue
« Reply #8 on: Sat, 07 February 2015, 09:46:27 »
Is this still an issue?  I placed an order a couple of weeks ago (invoice number 3182) but now I can't sign in, and the site doesn't recognise either of my e-mail addresses or my username to send a password reset to.
Help?
Offline Synjin
Re: PMK Login Issue
« Reply #9 on: Mon, 09 February 2015, 14:42:12 »
Same here.
