Author Topic: BSP Keycaps Question  (Read 1839 times)
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« on: Fri, 06 June 2014, 10:29:30 »
Does anyone know if BSP only makes keycaps with a non-ANSI bottom row? I was looking at http://www.originativeco.com/collections/keysets and they have the classic beige offered with different colored text, but no option for an ANSI bottom row.
I've heard quite a bit about the high quality of BSP and GMK keycaps.  I'm curious, does BSP only sell keycaps in the layout found on the Originative website?
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: BSP Keycaps Question
« Reply #1 on: Fri, 06 June 2014, 11:03:16 »
They only make 1.5 modifier and do not have spacebar and only stepped caps lock key. It's still a standard ANSI set only, just older style for winkeyless like G80-1000. Their key molds were made in mid 80's and they never invested to make new ones for modern standard.
If you want set in modern standard with 1.25 modifier and fulltouch caps lock I suggest to get a set from imsto in thick Cherry profile. They are almost as nice and do not cost as much either.
« Last Edit: Fri, 06 June 2014, 11:05:35 by IvanIvanovich »
« Reply #2 on: Fri, 06 June 2014, 11:30:21 »
That makes sense.  Thanks!
