Author Topic: [GB] The Smallfry Keyboard Kit (Closed for Orders, 97% shipped. SEE LAST POSTS)  (Read 526512 times)
Offline daddytime
  • Tell Daddy.
Re: [GB] The Smallfry Keyboard Kit
« Reply #100 on: Mon, 09 June 2014, 13:39:01 »
30!! Helll yeahhhhhh!!!!!!!!!!!!!!!!!!!!!!!!!!
Tell Daddy.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #101 on: Mon, 09 June 2014, 16:05:19 »
I'll build 5 of these if people don't want to do themselves - will be $25 per board which I will donate 100% of.
note that margo is in the EU
I will offer the same in the US.  Located fairly central in Iowa.  I would like to note this would just be the physical assembly.  I don't have enough experience in the software side to feel comfortable doing firmware.
« Last Edit: Mon, 09 June 2014, 16:13:47 by Melvang »
Offline shrapneL
« Reply #102 on: Mon, 09 June 2014, 16:45:40 »
So excited for this!
hello.
« Reply #103 on: Mon, 09 June 2014, 16:48:04 »
Also, for additional donations to the NJW foundation, please hold onto your money for now. I am still waiting to hear back from Largefry re: the status of the trust. Ideally, it's best if additional donations go directly to him. However, if you donate to geekhack via the donation buttons anywhere on this site and put "please donate this directly to the NJW foundation" or anything to that effect, I will make sure that the money gets to the NJW foundation.
I contacted him as well. I won't be getting in on this buy since I've had bits and pieces of the board for a while but I'd still like to donate.
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #104 on: Mon, 09 June 2014, 16:56:33 »
On behalf of TechKeys, I want to sponsor Diodes for everyone.
Ming - please get a hold of me to work out details.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #105 on: Mon, 09 June 2014, 17:02:39 »
ygm
Offline Pacifist
  • on hiatus
« Reply #106 on: Mon, 09 June 2014, 17:09:11 »
Hype!
« Reply #107 on: Mon, 09 June 2014, 18:02:33 »
I will provide a "default" firmware so that everyone can program their Teensys. Also, I believe metalliqaz' Easy AVR firmware will work with these. Either way, all you have to do to load the firmware onto the Teensy is to use PJRC's excellent Teensy Loader software.
Offline Pacifist
  • on hiatus
« Reply #108 on: Mon, 09 June 2014, 18:05:10 »
I highly recommend metalliqaz's firmware, its simple but also highly powerful. There's 10 layers, perfect for the 40%
Offline daddytime
  • Tell Daddy.
« Reply #109 on: Mon, 09 June 2014, 19:42:12 »
So dope!
Tell Daddy.
Offline shrapneL
« Reply #110 on: Mon, 09 June 2014, 20:37:23 »
This is awesome guys. You're all the best! :)
hello.
Offline mkawa
« Reply #111 on: Mon, 09 June 2014, 21:02:11 »
I have to say, I'm kind of shocked. If orders come in at the current rate, we will be out of units by this weekend.
At this point, I'm optimizing the total available units by my ability to keep my own sanity.
However, if we're almost sold out by Thursday, when the material order goes in, I guess I'll have to buy more? Again, shocked.
By my current estimates, as of right now, there are 43 more units available. Have at it, I guess :)
Offline byker
  • Literally Canada
« Reply #112 on: Mon, 09 June 2014, 23:17:36 »
Just pulled the trigger after looking through the 'Post your 40%' thread. I can't wait!!
Offline slickmamba
« Reply #113 on: Tue, 10 June 2014, 00:01:48 »
So if I just bought a weller last week, do I not qualify for the extra pcb =/
Hi :)
Offline byker
  • Literally Canada
« Reply #114 on: Tue, 10 June 2014, 00:19:45 »
I was eyeing up the $35 kit to go with the keyboard, but someone snagged the last one.
Offline LechnerDE
« Reply #115 on: Tue, 10 June 2014, 02:12:37 »
I already asked Thechemist to assemble mine, but since he is in the US it might make more sense to ask you.
How would it work? What's the total costs? 25$ for assembly + switches?
How do I order a kit so you will get it?
Offline margo baggins
  • Dungeon Dweller
  • Get back to work!
« Reply #116 on: Tue, 10 June 2014, 05:06:03 »
Errm, I have some instructions somewhere - I will send them to you later :D
I got boards.
Offline LechnerDE
« Reply #117 on: Tue, 10 June 2014, 05:26:59 »
Thanks  :thumb:
Offline dashing_girlboy
« Reply #118 on: Tue, 10 June 2014, 08:03:03 »
ordered!
just curious, when will this GB end? Is there a deadline or a target number to reach?
Offline Hellmark
« Reply #119 on: Tue, 10 June 2014, 08:26:29 »
Would it be possible to buy just the PCB? $159 is bit pricy for me right now (especially since that is before controller, switches, and caps), and I'm kinda wanting to make a things a bit different anyway (want to make a clamshell tablet case with a keyboard built in).
Offline Pacifist
  • on hiatus
« Reply #120 on: Tue, 10 June 2014, 11:00:10 »
Just a PCB won't be much use unless you get a plate machined yourself
« Reply #121 on: Tue, 10 June 2014, 11:03:01 »
Not to mention that's going to be one THICK tablet case. The minimum distance between the bottom of the top plate and the top of the bottom (plate, housing, whatever) is 0.5 inches (12mm). Because the Teensy sticks off the back of the PCB, and has a USB connector there.
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #122 on: Tue, 10 June 2014, 11:04:36 »
what's the best/cheapest source to get plate-mounted stabilizers for this beauty?
Offline Pacifist
  • on hiatus
« Reply #123 on: Tue, 10 June 2014, 11:07:57 »
mkawa is working on getting plate mounted stabs for geekhackers.org
Apart from that, whiskeytango was selling used ones from wyse boards, but he locked that thread
My source is scavenged from old boards
And I do belive that if you clip the ends of a PCB mount it will fit
« Reply #124 on: Tue, 10 June 2014, 11:09:40 »
Nope. They don't have the notch that mounts to the plate. :(
Offline mkawa
« Reply #125 on: Tue, 10 June 2014, 15:11:26 »
heads up! my laser-cutter was able to fit two more NOTCHED plates on the sheet of Ti that I had on hand. first come first serve!
http://www.geekhackers.org/products/jd40-40-keyboard-titanium-switch-plates-with-notches-for-switch-disassembly
Offline Vibex
  • Love y'all
« Reply #126 on: Tue, 10 June 2014, 15:18:38 »
Just bought one. Can you combind it with the shipment to TheChemist to save on shipping costs? And did you say before that you would offer a discount for people who bought them so you didn't have to send them a new notched and unotched plate?
Offline mkawa
« Reply #127 on: Tue, 10 June 2014, 15:48:11 »
yes and yes
Offline Vibex
  • Love y'all
« Reply #128 on: Tue, 10 June 2014, 15:50:34 »
yes and yes
Awesome. I was really sad when I didn't have the cash to buy it the first time around. Really glad you found some space for more.
Offline Hellmark
« Reply #129 on: Wed, 11 June 2014, 01:44:21 »
Getting a plate to spec wouldn't be an issue. Plus if I am having stuff made for the rest of the case, it is nothing more to add on a plate. Plus I'd like stainless steel, so I could polish it up. Thickness isn't really much of a concern. I wager it'd be a bit over an inch thick all said and done, but not a biggie. Some of the things I carry are that sized anyway. Still way more portable than a 15" laptop, and all the gear that needs.
Offline tbc
« Reply #130 on: Wed, 11 June 2014, 01:56:10 »
^post pics once you're done ya?  or even inprogress pic :D
Offline slickmamba
« Reply #131 on: Wed, 11 June 2014, 02:15:19 »
damn training, missed these again =/
Hi :)
Offline taylordcraig
« Reply #132 on: Wed, 11 June 2014, 03:54:52 »
Any chance I could just get a Ti bottom plate?
I have a constructed JD40 and cutout top plate.
there's going to be a limited number of bottom plate-only kits, and priority will go to the people who had notched ti top plates cut. the last few cuts are in flux though, so i'm not exactly sure how many extra bottom plate units there will be.
I got one of those notched top plates. Shouldn't be an issue, then?
Possible to get it without the PCB, too? Should I use the order form in the OP?
If I could get a bottom Ti plate set, I could sell you my extra pcb [I already have a constructed jd40]
mkawa please respond on how I order this [sorry if I missed it before. It's late and I don't want to miss this  buy]
Offline mkawa
« Reply #133 on: Wed, 11 June 2014, 07:45:02 »
if there are extra bottom plates after all the gb orders are sent out, i'll vend the parts separately. we're still talking about PCBs. for partial kits where you haven't purchased a notched plate already, best to wait until after the gb.
Offline mkawa
« Reply #134 on: Wed, 11 June 2014, 07:46:04 »
also, there are 30 kits left at the 6 sheet tier according to my stock-o-meter. if 15 more orders come in before i order sheets tomorrow, i guess i'll be buying 8.
ps, you people are crazy :eek:
Offline mkawa
« Reply #135 on: Wed, 11 June 2014, 14:16:38 »
state of the GB: currently at 40 orders, which is about 3 full sheets, and orders seem to have calmed down since the weekend. i will be going through the orders tomorrow to give partial refunds to people who ordered both a notched plate and a kit.
« Reply #136 on: Wed, 11 June 2014, 14:38:07 »
I purchased a notched plate.
What is my next course of action.
Judging by your above post I should place an order for a full kit and await a refund?
edit: i don't have the money to order one of these now. but i dont want to miss out on a ti bottom plate.
I can borrow money or something to get one of these NOW if that's the only way to 100% make sure I get one.
Else I'll wait until after and just get a bottom plate or bottomplate/pcb kit.
Offline Zeal
    • Zeal Generation Inc.
« Reply #137 on: Wed, 11 June 2014, 14:40:46 »
We should totally have these kits laser etched with x/40  :cool:
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #138 on: Wed, 11 June 2014, 15:04:07 »
That's a great idea! says the guy who have no idea what it would take to do that
« Reply #139 on: Wed, 11 June 2014, 15:13:15 »
I have access to a laser engraver, but I've never engraved on titanium. So I have no idea of the quality of the result. You can see how it looks on stainless steel here:
I don't mind engraving a logo and/or  [number] of [total] on them, if it looks good on titanium. But shipping across the country and back would definitely increase the cost per unit.
Offline Zeal
« Reply #140 on: Wed, 11 June 2014, 16:01:37 »
That badge is beautiful! I personally wouldn't mind chipping in some more (if your laser cutter can cut Ti) to make this SmallFry board even more special, to commemorate Nathan Walker.
Offline Vibex
  • Love y'all
« Reply #141 on: Wed, 11 June 2014, 17:12:09 »
I agree with Zeal, this would be awesome. ;D
Offline Grendel
« Reply #142 on: Wed, 11 June 2014, 18:34:38 »
Would prefer the back plain, sorry.
- I'm game !
Offline GSimon
« Reply #143 on: Wed, 11 June 2014, 18:53:04 »
+1
I can understand the appeal and design wise it looks good, but it's not for me.
« Reply #144 on: Wed, 11 June 2014, 18:57:18 »
+1
Just to be clear, that image was just an example of how laser engraving looks on stainless steel. The actual JD40 logo is still being designed (by lastpilot).
Offline byker
  • Literally Canada
« Reply #145 on: Wed, 11 June 2014, 22:03:03 »
+1
If it came as a badge, like the one pictured above, people could have the option of using it or not.
« Reply #146 on: Wed, 11 June 2014, 22:08:32 »
I am offering FREE assembly service for the first 5 4 3 2 individuals ( just post in the thread ) that perhaps don't have any soldering equipment but would still want to purchase this keyboard.
I would prefer it to be in the USA, all I ask is for you to pay the shipping.
If you are happy with the assembly and want to send any money for the service please message Mkawa so that he can get the money to Smallfry's family.
I know a few others have also chimed in already, but I'd like to add my services to the mix.  I will assemble up to 5 of these completely free of charge as well.  It seems like this might not be needed, but oh well.  The option is there.  :)
Offline GSimon
« Reply #147 on: Wed, 11 June 2014, 22:11:16 »
I should stop skim reading. I would like this as a badge, it appeals to me in this form :).
Offline tbc
« Reply #148 on: Wed, 11 June 2014, 23:41:43 »
+1
same here.  i would really rather just get it into my hands asap as well.
« Reply #149 on: Thu, 12 June 2014, 12:19:54 »
Purchased the Ti back plate. Thank you.
I would love a badge I could optionally attach to my case.
Smallfry(Jd40)
xx/yy
But I guess I didn't order a whole board.  :p
edit: oh yeah, any word on the RoR key caps?
