Author Topic: TTeSports Metal keycapss  (Read 3367 times)
Offline aatje92
« on: Sat, 07 June 2014, 04:57:39 »
Don't know if this is the right forum, but these upcoming caps look awesome (they need to work a bit on the centering of the legends imo, so OCD warning):
https://www.facebook.com/TteSPORTS/posts/10152293368478122
Currently using a SteelSeries 6gv2 (black switches) and a Ducky Zero DK2108 (blue switches).
Offline Razor Lotus
Re: TTeSports Metal keycapss
« Reply #1 on: Mon, 09 June 2014, 10:03:42 »
Looks just like ones that we can already get though
« Reply #2 on: Mon, 09 June 2014, 10:04:55 »
The Zinc caps aren't durable. I think on OCN or reddit, there were pictures of the tarnish and breakdown of the zinc coating on caps after 6 months. They looked horrible. Anyone know what picture I'm referring to?
« Last Edit: Tue, 10 June 2014, 08:34:27 by CPTBadAss »
Offline pr0ximity
« Reply #3 on: Tue, 10 June 2014, 07:18:19 »
The Zinc caps aren't durable. I think on OCN or reddit, there were pictures of the tanish and breakdown of the zinc coating on caps after 6 months. They looked horrible. Anyone know what picture I'm referring to?
Here's the thread:
http://www.reddit.com/r/MechanicalKeyboards/comments/1jnbsr/why_i_wouldnt_recommend_zinc_key_caps_photos/
« Reply #4 on: Tue, 10 June 2014, 08:34:38 »
That's the one, thanks!
Offline divito
« Reply #5 on: Tue, 10 June 2014, 11:30:47 »
The ones from Reddit are disgusting and I can't imagine that being the result of proper maintenance. Zincs with legends are, though, more prone to wear and trouble if you're not taking care because of the reduced coating in the areas of the legend itself, making it easier to break down.
I've had a blank 37-key set put through heavy use over 6 months, and there are no chips or wear at all so far.
If you decide on the legended caps, you'll simply have to take care on your usage. Perhaps rotate them out every once in awhile, make sure to take care of hygiene, and develop habits to avoid extra wear, like resting and rustling fingers while on the keys.
« Last Edit: Tue, 10 June 2014, 11:38:52 by divito »
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline baldgye
  • Will Smith Disciple
« Reply #6 on: Tue, 10 June 2014, 12:56:50 »
WQER
Offline pr0ximity
« Reply #7 on: Thu, 12 June 2014, 10:59:29 »
Makes a lot of sense given that the corrosion on those caps in the reddit thread all originates around the legends.
