Author Topic: [help]Found an IBM Model F, and it controls my mouse  (Read 3393 times)
Offline Hitcha
« on: Sat, 07 June 2014, 20:07:44 »
Pictures here: (http://imgur.com/a/hJ5sT)
Found an IBM Model F in a friend's shed. Didn't have the right adapter for it (doesn't use PS/2), so I bought one off of Amazon so I could use it.
(http://www.amazon.com/dp/B0016RTO1M/ref=pe_385040_30332190_TE_3p_M3T1_ST1_dp_1)
I'm using it to convert the signal to a PS/2 converter which in turn converts into USB.
Once I plug it in, it starts acting crazy. The LED indicators light up, then go dark. After that, every time I press a key it either moves my mouse, randomly clicks, or starts to scroll. It also disables me from using my real mouse in the process.
I've already opened it up a bit, cleaned out the dust and cobwebs, even made sure the circuit board was clean once I reassembled it, but I'm still having the same issues with it as before.
Any help or advice would be appreciated! Thanks for reading.
Full Metal Poker II - http://imgur.com/a/xK2Uv
Re: [help]Found an IBM Model F, and it controls my mouse
« Reply #1 on: Sat, 07 June 2014, 20:19:02 »
Does your adapter only have 4 pins in it?  And are you plugging it in before you start your computer?
Offline Hitcha
« Reply #2 on: Sat, 07 June 2014, 20:28:28 »
The adapter accepts the full five pins from the Model F, and I just tried plugging it in before I booted up; still no dice.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #3 on: Sat, 07 June 2014, 20:29:58 »
If it's a low quality PS/2 -> USB converter it could be a source of the problem.  What are you using?
« Reply #4 on: Sat, 07 June 2014, 20:32:02 »
I was asking about on the PS/2 side, the AT side looked right.  That said, I looked at it wrong the first time, I thought it was lacking the keyboard data and clock pins, but I had it flipped when I looked at it.
It could be your motherboard doesn't play well with PS/2 and you need an active PS/2 to USB adapter.
Offline Hitcha
« Reply #5 on: Sat, 07 June 2014, 20:32:44 »
This one here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812156004
Works perfectly with my Model M.
« Reply #6 on: Sat, 07 June 2014, 20:35:24 »
Some just don't work well with different keyboards.  Just because it works with an M doesn't mean it will work with an F AT.  I know this one works with a F AT since I've used one on an F AT, M, and Chicony with Monterey Blues.
Offline Hitcha
« Reply #7 on: Sat, 07 June 2014, 20:43:09 »
Looks like I'll order one of these and see if it helps with the issue.
Offline mougrim
« Reply #8 on: Sun, 08 June 2014, 11:35:24 »
You can try Blue Cube - http://www.amazon.com/PS2-Keyboard-To-USB-Adapter/dp/B000BSJFJS
Works perfect with my IBM AT Model F. And costs less - if you have AT to ps/2 adapter. Which you have.
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline JPG
  • Model F is my new passion!
« Reply #9 on: Sun, 08 June 2014, 11:48:46 »
The other option to consider is to build a Soarer converter!
Offline Hitcha
« Reply #10 on: Sat, 12 July 2014, 23:13:13 »
Although it's been a while since I first posted this, the problem was the converter I was using. After getting an active converter the keyboard worked perfectly! Thanks for your help guys!
Offline mougrim
« Reply #11 on: Mon, 14 July 2014, 12:23:30 »
So which one you got?
Offline 1391406
« Reply #12 on: Mon, 14 July 2014, 12:32:45 »
I'm assuming the Blue Cube.
Offline Hitcha
Offline mougrim
« Reply #14 on: Tue, 15 July 2014, 00:28:00 »
Well, I'd bought BlueCube, but if this one works, it doesn't matter. Plus - you can plug some vintage mouse :)
Offline dantan
« Reply #15 on: Tue, 15 July 2014, 16:25:34 »
Isn't it awesome to have a vintage keyboard that controls the mouse  :p   When the keyboard came out people were not using mice?
