Author Topic: Any Dota 2 players with Poker IIs?  (Read 3396 times)
Offline combataran
« on: Mon, 09 June 2014, 00:23:43 »
I'd like to know how you use your Poker IIs, specifically the lack of the Fn1~12 keys. And the other keys as well when you're not playing.
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline hindsight
Re: Any Dota 2 players with Poker IIs?
« Reply #1 on: Mon, 09 June 2014, 01:03:48 »
Although not exactly what you're looking for, I use an HHKB with my right hand when I play.
I've grown accustomed to just using [Fn+toprowkeys] for all my function keys. Ignoring the spectator commands, the only important things I even leave up there are the scoreboard, pause, and console.
For regular computer usage, the only thing that bugs me with these 60% boards sometimes is the lack of a numpad.
Offline PointyFox
« Reply #2 on: Mon, 09 June 2014, 01:04:42 »
I play DotA 2 and I had no idea the function keys did anything.  I'll check it out next time I'm playing :P
« Reply #3 on: Mon, 09 June 2014, 01:43:31 »
If you need the function keys, I recommend the fn lock mode and remap the function layer to that of your choosing.
Offline flaming_june
« Reply #4 on: Mon, 09 June 2014, 03:24:11 »
Don't do it.  Fm+num keys makes the game literally, unplayable.
Offline feizor
« Reply #5 on: Mon, 09 June 2014, 04:09:35 »
On my poker F keys are accessed with capslock + 1, 2, 3, 4 etc.
What do you need the numpad for in Dota?
Offline singaporean123
  • I like keycaps and I cannot lie
« Reply #6 on: Mon, 09 June 2014, 04:45:42 »
I change F1-> 1.
that's about it lol
Offline Tym
« Reply #7 on: Mon, 09 June 2014, 05:51:33 »
F4 brings up the shop :)
Offline Defect
« Reply #8 on: Mon, 09 June 2014, 06:06:11 »
Dota is easier with dedicated F-row.  But you can always remap the camera controls.
I use my 60 for most games but Dota requires the Choc Mini :)
Offline Razor Lotus
« Reply #9 on: Mon, 09 June 2014, 09:55:24 »
I play dota on my KBT pure. I just change f1 to 1, f2 to 2 and all that cause I don't really use the numbers in the first place.
For pause and unpause i just press fn +9 for F9.
