Author Topic: [FS] Rubber Mats Pads for Keyboard - EPDM dense rubber industrial material  (Read 87046 times)
Offline thatsmrdoctortoyou
  • Dingo babies
    • IG
Re: [FS] Rubber Mats Pads for Keyboard - EPDM dense rubber industrial material
« Reply #50 on: Wed, 24 August 2016, 20:55:37 »
Emailed re: extra-small rubber mat!
« Reply #51 on: Fri, 30 September 2016, 08:21:05 »
- D Trump 2026-10-24
Offline Zealousy
    • Twitter
« Reply #52 on: Sun, 02 October 2016, 01:04:20 »
I'd love a video review of these mats!
Offline captsis
  • Formerly matt2dlg
« Reply #53 on: Sun, 02 October 2016, 01:19:04 »
Can they be used as a mosepad if I bought a large one? are they heat resistant for soldering? sorry if dumb questions
« Reply #54 on: Sun, 02 October 2016, 12:00:12 »
I have one and don't think it will make a very good mouse pad.
« Reply #55 on: Wed, 05 October 2016, 07:43:48 »
It would be a terrible mouse pad.
Imagine the material of an inner tube, only quite a bit thicker and stiffer. My ebay description used to say "non-slip" but I got a complaint from one buyer who said that it did not help slippage, so I removed that term. Personally, I do consider it to have good traction and that is why I like it.
I use a piece on my work table sometimes and it is very tough. Incidental drops of solder probably wouldn't hurt it, but you couldn't actually lay a hot iron down on it without melting (and smelling terrible, I would guess).
« Reply #56 on: Mon, 19 December 2016, 16:36:54 »
I haven't visited lately.
still available
I still use one of these under my daily driver at work. :thumb:
And at home. : thumb:
« Reply #59 on: Thu, 05 October 2017, 06:22:53 »
bump to move this up the list
« Last Edit: Thu, 05 October 2017, 20:24:22 by fohat.digs »
Offline probros69
« Reply #60 on: Tue, 10 October 2017, 20:10:44 »
Hello,
I just bought a few mats from fohat.digs a few days earlier.
Attached are pictures of the mat that I have on hand at the moment.  It's not especially slippery or grippy, which is fine for me.
If you are extremely heavy on your keyboard movements, you might actually move the mat slightly sometimes.  I have never had any such troubles, but I could move my keyboard if I give a little extra push.
At first, the mat looks pretty ugly, but after a while, its grown on me, and I don't really see it much.
If you want some cheap mats made to size, I'd highly recommend most people to buy these.
« Reply #61 on: Tue, 10 October 2017, 20:52:16 »
I still use these daily at home and at work.
« Reply #62 on: Tue, 10 October 2017, 20:55:44 »
Hello,
Looks simple and functional, which is all you'd want!
« Reply #63 on: Wed, 11 October 2017, 13:24:59 »
Thanks, guys. This is an industrial roofing material so it is not intended to be pretty, but on the other hand is extremely tough since it is made to have a 25-year warranty while exposed to the elements!
It is not soft or grippy like sorbothane, and would be terrible under a mouse, but it is a great utilitarian underlayment.
« Reply #64 on: Wed, 11 October 2017, 13:40:28 »
Yup; still got mine under my Realforce at work. I got one with excess mat with the intention to cut it and fit under the board, but I've kept it on and use the remainder for resting my fidget toys.
Offline Gampela
« Reply #65 on: Thu, 02 November 2017, 11:16:02 »
I'm wondering if I could save a bit money and buy this instead of the official HHKB Vibration Absorption Mat. Anyone have both to compare? Also would you be willing to cut it in about same dimensions.   A bit undersized and leaving free spaces for front and back feets and the 3 screws in the back. Like this: http://www.smartimports.net/hhkb-vibration-absorption-mat
« Reply #66 on: Thu, 02 November 2017, 11:28:51 »
No reason to cut one of these mats up just use it how it comes for the hhkb.
Offline Gampela
« Reply #67 on: Thu, 02 November 2017, 11:36:39 »
I was just kinda thinking about attaching it properly on my keyboard so it would need cutouts. But I guess I can do that with normal scissors myself if I ever feel need to.
Anyways do you still have the materials?
« Last Edit: Thu, 02 November 2017, 11:38:33 by Gampela »
Offline probros69
« Reply #68 on: Fri, 03 November 2017, 19:03:10 »
The anti-vibration mat from PFU is much thicker and has better grip than the rubber mats that I got from fohat.digs.  I'll attach a  picture to give you an idea of how the anti-vibration mat looks compared to fohat.digs's mats.
Like fohat.digs mentioned earlier, his mats are utilitarian and they are great for preventing more important things from getting damaged.  I like to put it under the PFU mat to keep the foam safe.
Offline Gampela
« Reply #69 on: Sat, 04 November 2017, 03:48:14 »
Thanks dude. This isn't what I need then. Sorry for spamming here.
« Reply #70 on: Fri, 22 February 2019, 15:29:23 »
PM sent.
Offline biosync
« Reply #71 on: Mon, 23 September 2019, 08:44:24 »
pm sent!
