Author Topic: Are there keyboards with split spacebars?  (Read 10181 times)
Offline nrd
« on: Mon, 09 June 2014, 18:16:02 »
Fiddling around with some of my hotkeys and trying to make my keyboard life a little more comfortable, I couldn’t help but notice that the spacebar is a huge waste of potential. It’s so easily accesible and takes up so much space yet it’s usually only used for a single function.
I already have a bunch of hotkeys around the spacebar (left shift + space, right shift + space, control + space and I’ll probably turn the latter into two distinct left/right control + space hotkeys) and it still feels like I could do so much more with it – if only it would be split so that I had a “left space” and a “right space” to work with. Actually I thought that splitting it into three keys would be even better, left, middle and center.
Are there any keyboards that offer this? Apart from ones like the ErgoDox and so on. Basically a standard ANSI/ISO layout with a split spacebar? If not … why not?!  :(
Offline epzy
  • HHKB Fiend
  • ded
Re: Are there keyboards with split spacebars?
« Reply #1 on: Mon, 09 June 2014, 18:18:32 »
Offline Pacifist
  • on hiatus
« Reply #2 on: Mon, 09 June 2014, 18:20:34 »
g80-5k
edit: tooslow :(
« Reply #3 on: Mon, 09 June 2014, 18:33:53 »
They used to be more common.
Accountants, in particular, used half for space and half for delete.
- D Trump 2026-10-24
Offline nrd
« Reply #4 on: Mon, 09 June 2014, 19:24:21 »
That’s a bit more split than I was hoping for  :D
Interesting. The G80-5000 was discontinued long ago (and wasn’t in production for long to begin with) and apart from that I could only dig up some even more obscure/old pics and a couple of ideas for custom boards …
No recent models that are readily available, from what I can see  :(
Offline Dubsgalore
« Reply #5 on: Mon, 09 June 2014, 19:38:04 »
Like the M15 :P Left for delete and Right for space
Offline jacobolus
Offline False_Dmitry_II
« Reply #7 on: Tue, 10 June 2014, 01:10:58 »
I've seen many more keys on that bottom row on other japanese boards.
« Reply #8 on: Tue, 10 June 2014, 03:54:56 »
Some vintage NMB keyboards with "Erase-Eaze" had a split space bar where the left one acted as Backspace. I remember seeing it posted on the forum.
BTW, the Matias ErgoPro allows either the left or right to be Backspace, but it is also a split ergo..
BTW 2. The USB HID standard actually has a special key code for the "Erase-Eaze" key. I dunno if it is supported by any OS without any special driver, though.
« Last Edit: Tue, 10 June 2014, 04:01:08 by Findecanor »
Offline nrd
« Reply #9 on: Wed, 11 June 2014, 11:52:32 »
Yes, I’ve noticed that, too. Can’t really find much on Japanese boards in general, unfortunately. Guess it would help if I knew Japanese  ;D
I did find a Japanese Corsair board, but that came with a really weird bottom row in general.
Well … and then there’s the Filco Minila:
Looks a lot like what I had in mind, except that it’s 60% and comes with an oversized left Ctrl instead of a second OS and Ctrl key. Too bad  :-X
  • Live long and prosper
« Reply #10 on: Wed, 11 June 2014, 11:54:22 »
The stock keyboard on my family's first computer had a split space bar. If only I knew the model number...
It was the keyboard from an old Compaq Presario from the Win95 era.
tp thread is tp thread
« Reply #11 on: Wed, 11 June 2014, 13:33:40 »
« Reply #12 on: Wed, 11 June 2014, 13:35:12 »
This one?
YES! That's exactly it!
I think MSW still has that computer and keyboard, I'll have to ask him...
Offline nrd
« Reply #13 on: Wed, 11 June 2014, 13:44:37 »
This is exactly the layout I was hoping for! 1.25 keys for the bottom row and a split spacebar. (Well, almost exactly my dream layout – a 3 part spacebar would be even better.)
The more I think about it the less I understand why layouts with a split spacebar are so unpopular among manufacturers :-X
The “Microsoft Sculpt Comfort Keyboard” comes with a split spacebar but of course it’s not a mechanical:
« Reply #14 on: Wed, 11 June 2014, 16:31:35 »
Only thing about that one is that it probably merely sends either backspace or regular space scan codes, so it wouldn't be easily remappable how you want it to be.
« Reply #15 on: Wed, 11 June 2014, 16:39:30 »
Don't forget the NMB erase-eaze.
one of the few spacebars with a label
I contend that the IBM wheelwriter keyboards also count.
who needs SSKs? when you can get these for $10
Then there's always DIY:
the BEST filco zero
from: http://st.cat-v.ne.jp/pgr/keyboard/filcoxmg.html
There's more but those are my fav.
Of course split keyboards like M15, G80-5000, kinesis and ergodox have split spacebars or can be set up that way.
« Reply #16 on: Wed, 11 June 2014, 16:43:05 »
What switches does the  IBM wheelwriter keyboard use? How easy is it to interface to PC?
« Reply #17 on: Wed, 11 June 2014, 17:13:22 »
I had one that was basic Model M-type buckling springs.
Offline ideus
  • Björkö.
« Reply #18 on: Wed, 11 June 2014, 18:52:13 »
the BEST filco zero
Very interesting posts, thank you for the information. After seen these boards I feel more informed on keyboards.
« Reply #19 on: Wed, 11 June 2014, 19:05:56 »
You would need a custom controller, but I have seen already at least one other person has been working on it.
