Author Topic: 2 Piece vs 1 Piece IBM Caps  (Read 7940 times)
Offline Pacifist
  • on hiatus
« on: Mon, 09 June 2014, 21:41:36 »
How does the feel compare? 1 piece is 100% solid but 2 piece doesn't seem too wobly
Re: 2 Piece vs 1 Piece IBM Caps
« Reply #1 on: Mon, 09 June 2014, 21:42:42 »
They feel the same to me. I can't tell a difference.
Offline Wildcard
  • When caffeine isn't enough
« Reply #2 on: Fri, 13 June 2014, 11:39:37 »
Same to me as well. The design of the 2 piece is very solid.
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #3 on: Fri, 13 June 2014, 11:51:46 »
The one piece caps feel vastly superior. Anyone who tells you different is wrong.
Offline Parak
« Reply #4 on: Fri, 13 June 2014, 12:05:25 »
The two piece caps feel vastly superior. Anyone who tells you different is wrong.
idontactuallyhaveanopiniononthismatter
« Reply #5 on: Fri, 13 June 2014, 12:05:33 »
I think that there is a difference, but it is very subtle.
Whatever additional tiny chatter there may be is washed away in the "catastrophic buckling" of the spring and the pivot plate rocking up and down.
- D Trump 2026-09-28
Offline jwaz
  • * based mod
« Reply #6 on: Fri, 13 June 2014, 12:19:13 »
Honestly, the only advantage I've found to the one-piece caps is that I can rock colemak without the home row keys in weird places.
Offline Techno Trousers
  • ʘ_ಠ
« Reply #7 on: Fri, 13 June 2014, 12:34:58 »
I don't notice any difference in feel.
Offline 0100010
  • Not Sure
« Reply #8 on: Fri, 13 June 2014, 12:35:49 »
The only 2 piece caps on my board are the 1.5x modifiers; they have no additional play that I can feel.
Offline vivalarevolución
« Reply #9 on: Sun, 15 June 2014, 15:06:38 »
I have both and I have not notice a difference.  The one piece leave a tad more space between the keys, but the two-piece are easy to move around if I want to do an alternative layout.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #10 on: Mon, 23 June 2014, 13:30:33 »
I never noticed a difference between them.
« Reply #11 on: Mon, 23 June 2014, 17:11:24 »
I have not noticed any difference in the feel.
But one thing 1-piece keycaps have over 2-piece is that you cannot lose the top piece.
Offline sleepy916
« Reply #12 on: Mon, 23 June 2014, 17:33:57 »
I prefer the 1-piece because the ones that I have seem to have darker/bolder lettering. To me the dye sub was better back then. The feel is unnoticeable for me though.
Offline ShawnMeg
« Reply #13 on: Sat, 02 August 2014, 06:12:30 »
I can't tell a difference.  I do like the 2 pieces in that changing the keycaps is fast and easy.
IBM Model F122 X 2 internal Soarer's || IBM Model M122 internal Soarer's || AEK II SKCM Salmon ALPS external adb_usb converter ||  AEK M0115 SKCM Orange ALPS click mod external adb_usb converter || AEK M0115 SKCM Salmon ALPS external adb_usb converter ||
Offline skcheng
    • Tenafly Dentistry
« Reply #14 on: Sat, 02 August 2014, 08:43:19 »
I like one piece better.    Caps don't come flying off with my blazing fast 55wpm speed!!
AT-F one piece > Model M SSK one piece >  Model M two piece.    Two piece caps much more common.
« Reply #15 on: Sat, 02 August 2014, 19:05:18 »
I have never had the top half of a 2 piece keycap come off accidentally :eek:
Offline berserkfan
« Reply #16 on: Sat, 02 August 2014, 22:01:26 »
kids know the difference. because they like pulling off and rearranging the caps, and obviously two piece are far easier to remove
Offline nameistaken1
« Reply #17 on: Sat, 02 August 2014, 22:06:56 »
But this makes cleaning SO much easier. Assuming one is the obsessive type that clean their keycaps constantly. I don't.
I can't tell a difference when typing. The two piece keys don't move around, if that's what you're thinking. The fit tightly, with clips on the bottom.
Offline berserkfan
« Reply #18 on: Sat, 02 August 2014, 22:58:32 »
when typing they do make a difference, if the kids have gotten their hands on the keycaps. that's how I end up without a single buckling spring keyboard that has a full set of keycaps of the same color. the kids pull everything off and rearrange to their liking and they transplant between keyboards with keycaps of a different color scheme
this is something that can't be done with adult fingers (too big to fit in the spaces between keys, so it's hard for an adult to remove a 2-piece top cap).
Offline orihalcon
« Reply #19 on: Tue, 05 August 2014, 19:19:25 »
Might be a little difference when it comes to the 1.5 sized keys like the "\|" key, but for the regular ones, I can't tell the difference.
