Author Topic: Build log - NCR 3077 Leeku  (Read 20842 times)
« on: Tue, 10 June 2014, 20:43:44 »
Some photos of my latest keyboard. It's taken about 6 months to source the parts for this. Totally worth it. These photos are resized. For full size photos please see the album on my flickr account. It's not really a full build log, since there wasn't much to do other than mod the switches, solder on diodes and solder on switches, but I tried to take a few shots mid-build.
Huge thank you to Irisveil and REVENGE for helping me get the PCB and case! ;D
Here are the parts :
The MXALPS-30XX PCB designed by Leeku. Meant to fit in Cherry G80/G81-3XXX cases.
NCR Logo
NCR branded G81-3077SAU case
Label
Nixdorf black
Sprits gold plated 65g spring
Throughhole diodes from G80 switches
Old Cherry PCB-mount stabilisers that use screws to mount
Lightly used ANSI doubleshots from a G81-3000HAU variant
Coiled PS2 cable from Cherry G81-3011HBG
A few pictures mid-build :
Soldering a diode to the SMD pads. I did this incase I ever need to desolder all the switches. Saves me from desoldering 4 pins per switch.
Switches soldered on. Stabilisers installed. Stabilisers lubed with GPL205/103 mix. Springs seated.
Switches closed up.
PCB installed in the case.
Windowed esc-row Cherry logo key taken from G80-2000HAD.
The finished build :
Thanks for looking. Hope you enjoyed.
« Last Edit: Tue, 10 June 2014, 20:50:44 by Photekq »
Offline Zeal
    • Zeal Generation Inc.
Re: Build log - NCR 3077 Leeku
« Reply #1 on: Tue, 10 June 2014, 20:50:09 »
Nice build, Photekq!
Question: Is there a difference in feel with old style PCB mount cherry stabs? Any design changes other than the screws?
Offline HPE1000
  • Keycap Paparazzo
« Reply #2 on: Tue, 10 June 2014, 20:50:40 »
Super nice, awesome work!  :thumb:
« Reply #3 on: Tue, 10 June 2014, 20:51:58 »
There is a difference between the STOCK old ones and STOCK new ones. Why? Look at the stems of the old ones. They're already pre-clipped.
I can't really feel much of a difference between these and clipped new ones. I use them because they will definitely never pop out :))
Offline Pacifist
  • on hiatus
« Reply #4 on: Tue, 10 June 2014, 20:51:58 »
Sexayyyyyyyyyyyy
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #5 on: Tue, 10 June 2014, 20:52:57 »
Klassico !  Klavier!!  ;)
Offline tinlong117
« Reply #6 on: Tue, 10 June 2014, 20:56:43 »
meh at the custom pcb.
« Reply #7 on: Tue, 10 June 2014, 20:57:38 »
Sell me an original 3000 PCB with NKRO, then I'll throw the custom one away :-*
Offline epzy
  • HHKB Fiend
  • ded
« Reply #8 on: Tue, 10 June 2014, 20:59:05 »
Perfection. :thumb:
Offline Michael
  • Formerly Bro Caps
« Reply #9 on: Tue, 10 June 2014, 21:00:18 »
This is fabulous, bro.
Offline tinlong117
« Reply #10 on: Tue, 10 June 2014, 21:04:41 »
Let's trade. Send one of your hot classmate to me and I will send a NKRO 3K pcb to you.
Offline Amble
« Reply #11 on: Tue, 10 June 2014, 21:04:54 »
Nice... you finally got one and it looks gorgeous.  Still wish I had the fortune of getting that one on ebay a while back.
« Reply #12 on: Tue, 10 June 2014, 21:08:09 »
My Hamburger case is going to be better than that :P
Just kidding, that's a lovely build and I'm even more excited to get my 3000 working.
Offline yicaoyimu
« Reply #13 on: Tue, 10 June 2014, 21:22:11 »
You got so many Nixdorf blacks...
Offline Dubsgalore
« Reply #14 on: Tue, 10 June 2014, 23:07:25 »
To think I passed up on the leeku :))
Dem delicious double shots  :] lookin sharp
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #15 on: Tue, 10 June 2014, 23:32:14 »
Very nice Photekq! :thumb:
Thanks for sharing!
« Reply #16 on: Tue, 10 June 2014, 23:42:09 »
The ones on this 3077 are the only ones I have :-\ Wish I had more for future builds.
Offline sleepy916
« Reply #17 on: Tue, 10 June 2014, 23:43:34 »
Fine, I'll give got $10 and not a penny more for this monstrosity! ....very nice.
Offline yicaoyimu
« Reply #18 on: Tue, 10 June 2014, 23:57:31 »
What about those on TEK-80.
« Reply #19 on: Tue, 10 June 2014, 23:59:37 »
They're the same ones. I ended up not using them since Phantom doesn't support PCB mount switches, and I didn't want to butcher them. TEK-80 is built with ergoclears.
Offline yicaoyimu
« Reply #20 on: Wed, 11 June 2014, 00:26:55 »
I wish I could get some nixdorf blacks for my end game board. RGB switch seems like a good alternative.
What is the advantage of using this Leeku PCB instead of Cherry PCB?
Offline damorgue
    • Personal portfolio
« Reply #21 on: Wed, 11 June 2014, 00:33:22 »
Nice build and excellent pictures. I will be using the image below as a reference for a project I am doing.
« Last Edit: Wed, 11 June 2014, 10:48:22 by damorgue »
« Reply #22 on: Wed, 11 June 2014, 00:50:39 »
I hope you can find some :) It's a very nice switch.
Leeku has NKRO, Cherry 3XXX PCBs don't. There are some Cherry 1XXX PCBs that do have NKRO, but they don't fit in 3XXX cases. So, if you want an NKRO 3XXX Leeku is your only choice. I play dota, so it's important for me to have it.
Offline Pacifist
  • on hiatus
« Reply #23 on: Wed, 11 June 2014, 01:05:09 »
Why no TKL for gaming?
« Reply #24 on: Wed, 11 June 2014, 01:06:43 »
Wasn't aware that Cherry sold TKLs in the 80s/90s.. :))
Offline Irisviel
« Reply #25 on: Wed, 11 June 2014, 01:08:35 »
congratulations:)
Offline Pacifist
  • on hiatus
« Reply #26 on: Wed, 11 June 2014, 01:09:10 »
Dam you are a cherry god
Offline tinlong117
« Reply #27 on: Wed, 11 June 2014, 10:02:14 »
Just hook it up with a ****ing teensy and you can get NKRO.
Offline tinlong117
« Reply #28 on: Wed, 11 June 2014, 10:02:43 »
I think... g80-5000 is nkro and tkl. Right?
« Reply #29 on: Wed, 11 June 2014, 10:04:57 »
Too much effort..
Oh yeah, you're right :-[ That is basically a TKL and I use one for gaming all the time ;D
Offline phetto
  • HHKB JP
« Reply #30 on: Wed, 11 June 2014, 10:08:22 »
Looks nice. Leeku pcb doesnt have ghosting, right?`
« Reply #31 on: Wed, 11 June 2014, 10:09:34 »
Holy ****, phetto is back! <3
And ugh, that NCR case is really nice. I'll offer $11 in an attempt to snipe sleepy916 :P
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #32 on: Wed, 11 June 2014, 10:56:58 »
Nice build.
You can't just hook up a teensy and get NKRO on a run of the mill 3000 PCB. The PCB have no traces for diodes, only pads that go nowhere for the wire tie downs. So unless you wanted to do a mess of handwire to hook up diodes that is a definite no go. With right firmware you might be able to get increase to 4KRO maybe like some other non diode G80 models... The only 3000 family PCBs that are easy to get that have NKRO are the 349X which are not winkeyless. There are some late 1000 series that do have a 3000 size PCB with NKRO (label will have FCC ID with 3000 part number, but there are also revision PCB that are same as 2KRO 3000 model so it's still no guarantee) though they are not easy to find.
Offline sleepy916
« Reply #33 on: Wed, 11 June 2014, 18:01:05 »
Damn... good snipe.  ^-^
Offline adamseto
« Reply #34 on: Mon, 07 July 2014, 11:44:26 »
I like your keycap :D
Name : Lê Duy Hùng ( Alex )
Cell phone : (+84) 979 13 49 53
Email : thanchetdemnoel@gmail.com
BBM : 2AA9E38E
OEM : Filco full red SW/Filco Camouflage full Brown SW/Realforce 108UDK/Realforce 87U Silent/Cherry ESA-3000-HASRO
Custom : KMAC2 VintageBlack 62g/360C Black 60G Gold/TheCheat Vintage Black 62G/Dolphin Vintage Black 60G/LZ-STAN
Offline meiosis
  • Time
« Reply #35 on: Sat, 22 October 2016, 20:44:42 »
Remember back when photekq was normal
Keyboards:
Aripeko TKL
Offline alienman82
« Reply #36 on: Sat, 22 October 2016, 22:58:58 »
removed.
« Last Edit: Thu, 01 March 2018, 13:52:56 by alienman82 »
« Reply #37 on: Sun, 23 October 2016, 01:12:17 »
It was a sad time devoid of all sarcasm and *******s.
