Author Topic: Custom layout advice  (Read 1549 times)
Offline qwack
« on: Wed, 11 June 2014, 11:28:46 »
I love my Pure Pro, but I regret that the bunch of non-standard keys makes it nearly impossible to replace keycaps with a homogenous set, even when using caps from a set of 104/105 blanks. So I'm thinking about making my own layout with more standard keys while retaining the arrow cluster in the bottom right hand corner (which I use a lot, often in conjunction with the right Alt modifier, which was the reason i got a Pure Pro).
Here what it could look like:
The only non-standard key would be the 1 unit Fn key, but that would be a minor problem compared to the current situation. The arrow cluster can be adjusted so as to allow any 1.25 modifier to be used as a Fn key:
With this layout, the biggest tradeoff is the lack of a right Shift key; I am not sure yet how much I'll miss it. The only modifier on the right of the spacebar I need is the right Alt (AltGr in french); I can live without the right Windows, App & Ctrl keys, which I've not used for years.
Also, I've ditched the CapsLock key and replaced it with the left Fn, which replicates the setup on my Pure Pro, which works very well for me.
So, do you have any suggestion? I'll remove the right Shift cap from my keyboard to see how I can live without this key, but in the meantime, I'm interested to hear if you have better ideas for the bottom right hand corner.
Also, since I want the largest possible compatibility with keycaps sets, is the 6.25 units space bar the best choice, and do you think I should go for an ANSI layout instead of ISO?
Pure Pro w/MX Red - [review]
Offline bueller
  • MX baller
  • Church of the Ergo Clear
Re: Custom layout advice
« Reply #1 on: Wed, 11 June 2014, 11:31:15 »
Honestly I'd say just go for an original Pure and enable the arrow mods. If you really miss the right shift you can just move it to the key on the far right of the shift.
Offline nrd
« Reply #2 on: Wed, 11 June 2014, 11:43:20 »
Definitely ANSI. More variety in available keycaps and it makes for a nicer layout overall, at least in my opinion. I used ISO all my life (I’m from Germany) and only switched to ANSI a couple of weeks ago, but I don’t regret the switch at all.
As far as the right shift is concerned: Personally I couldn’t live without it, but if you’re interested to see how much you really use each key of your keyboard, you could always use a tool like WhatPulse to create a keyboard heatmap:
That way you can see exactly how much use you make of a specific key. Quite interesting :)
Offline qwack
« Reply #3 on: Wed, 11 June 2014, 11:55:59 »
This is most interesting, thank you! And yes, the more I think about it, the more I'm leaning towards shifting to ANSI.
bueller, thanks for your advice. I actually considered waiting for the GH60 to become available and build one with a Pure layout, but I was put off by the nonstandard keys. I'll check again to see what I could do with this PCB/plate.
Offline ideus
  • Björkö.
« Reply #4 on: Wed, 11 June 2014, 12:17:07 »
If the point is to use standard sets, ANSI is the way to go, most available sets, and GB are mainly focus in ANSI users. Some adds ISO enter and a couple of other keys for compatibility, but again you are forced to get special subsets.
