Author Topic: **OPEN as of 8/4/15** Tigersharkdude's Wooden Wrist Rests  (Read 130574 times)
Offline ghostjuggernaut
Re: **OPEN as of 8/4/15** Tigersharkdude's Wooden Wrist Rests
« Reply #200 on: Thu, 06 August 2015, 10:16:47 »
I'm interested in a wrest, once you are able to work with hardwood again.
Offline tigersharkdude
« Reply #201 on: Thu, 06 August 2015, 11:03:49 »
I am, I'm currently working on 3 so it will be a few days before I can accept another
EDIT: I can't do any HARD wood. My saw isn't nice enough to cut it.
« Last Edit: Thu, 06 August 2015, 13:42:26 by tigersharkdude »
Offline Cebu
« Reply #202 on: Thu, 06 August 2015, 11:34:52 »
That's fine, is there a waiting list and are you only able to do pine or whitewood still?
« Reply #203 on: Thu, 06 August 2015, 11:45:09 »
I can do pine, whitewood or Cedar (cedar is option 3 only). There is no waiting list ATM, you would be #1
Offline Cebu
« Reply #204 on: Thu, 06 August 2015, 11:55:40 »
Sign me up, I will definitely buy one. I only want option 3 anyway, but the problem is.. I am not to familiar with wood choices and finishes. I'm looking to get a rest that fits a tenkeyless board (Varmilo VB87M) and has a smooth/darker (not too glossy more matte) finish. The plank and cedar wood rests from the previous posts look great, so I wouldn't mind either wood.
« Last Edit: Thu, 06 August 2015, 11:57:17 by Cebu »
« Reply #205 on: Thu, 06 August 2015, 12:12:19 »
Ok, I'll get some pics of the 3 different woods in Option 3.
"The plank and cedar wood rests from the previous posts look great, so I wouldn't mind either wood"
Plank is a type of keyboard, the rests for those are made of pine. The one that has no finish or poly is made of cedar. I have an ebony stain BUT it is dark, almost completely black.
Offline aznairjordan
« Reply #206 on: Thu, 06 August 2015, 13:19:35 »
Just showing my interest atm, have you made one for hhkbs? Will be getting an hhkb in october and I would love to have one then.
TGR Jane CE|FC660C|Orion V2
GMK Hyperfuse|GMK Olivetti|GMK Red Alert|Soulfree's Teal|GMK Cyan
« Reply #207 on: Thu, 06 August 2015, 13:20:45 »
I'm not positive, but if you get me the length I can make one for sure.
Offline Cebu
« Reply #208 on: Thu, 06 August 2015, 13:30:00 »
I see. I like the pine better, but I'll wait to see what whitewood looks like. I also want to see what an ebony stain looks like. I forgot to add, I also like the slight curve you put on the plank pieces.
« Reply #209 on: Thu, 06 August 2015, 13:34:05 »
White wood and ebony would look the same as pine. The grain between them is very similar
Most pieces will have a good curve to them, Hwoods  piece is so narrow that the entire piece is an angle instead of having a curve
I sent you a PM earlier with a pic or two in it
« Last Edit: Thu, 06 August 2015, 13:40:45 by tigersharkdude »
Offline Sed8op8
  • Keyboard Padawan
« Reply #210 on: Fri, 07 August 2015, 07:19:28 »
Really bummed I hadn't seen these before ! They look freaking beautiful tiger 8)
« Reply #211 on: Fri, 07 August 2015, 07:50:56 »
Gracias
Offline cmadrid
« Reply #212 on: Fri, 07 August 2015, 10:24:43 »
Mine is still as nice as the day I received it!
« Reply #213 on: Fri, 07 August 2015, 10:31:02 »
Awesome to hear
« Reply #214 on: Fri, 07 August 2015, 18:41:25 »
Update
Finished Enddot's 2 planck pieces and Hwood's cedar TKL piece
« Last Edit: Tue, 11 August 2015, 07:27:22 by tigersharkdude »
« Reply #215 on: Sat, 08 August 2015, 08:31:33 »
OP updated with new pictures and such
Offline enddot
« Reply #216 on: Mon, 10 August 2015, 08:11:37 »
The keyboard is named after Max Planck (Planck's constant) whereas plank is for wood. So I guess I ordered planks for plancks.
« Reply #217 on: Mon, 10 August 2015, 08:26:01 »
Now I know, I've always seen it spelled 'plank'
« Reply #218 on: Tue, 11 August 2015, 07:26:37 »
New piece I'm working on, it's for a Varmillo TKL. The stain is English Chestnut mixed with Ebony a there is no poly on it yer
Offline enddot
« Reply #219 on: Tue, 11 August 2015, 07:48:40 »
They came in yesterday and they work nicely. I found however after long use my wrist 'sticking' to it from being a bit humid/sweaty. I'm thinking about lightly sanding to smooth it though is that the right way to approach this?
« Reply #220 on: Tue, 11 August 2015, 08:12:41 »
You may need to give it a few more days to completely cure. If you sand it it will likely lose its gloss unless you have some polishing compound on hand (I use car polish)
« Reply #221 on: Thu, 13 August 2015, 11:45:05 »
Update on Cebu's piece. It's for a Varmillo TKL, the stain is a mixture of English Chestnut and Ebony.
Do note that it's not finished, I still need to wetsand it smooth (the new poly is like water -___- and it runs like crazy ... I am not a fan of it at all)
« Reply #222 on: Fri, 14 August 2015, 15:24:12 »
ye old wrist rest is finished
Offline shrubkeys
« Reply #223 on: Thu, 20 August 2015, 16:16:28 »
Interested in doing a bottom piece with negative slope?
« Reply #224 on: Thu, 20 August 2015, 17:41:44 »
^^not sure what you mean. I need more information
Offline cmadrid
« Reply #225 on: Thu, 20 August 2015, 19:15:15 »
Lookin good!
Offline shrubkeys
« Reply #226 on: Thu, 20 August 2015, 22:06:19 »
"Negative" angle is where the front of the keyboard is higher than the back. This is the opposite of where keyboard feet/risers normally come, but - depending on the size of your hands and the details of your setup - is arguably a better posture ergonomically, and is certainly kinder on your wrists. For built-in examples, see the Microsoft 4000 or Sculpt. When people are writing about "tiliting" in addition to "tenting" with regard to their Ergodox, this is what they mean. ("Tenting" is the angle of the sides.)
Actually, all I really want is enough of a slope to counteract the HHKB's slightly agressive forward angle, and make it overall flat.
Failing this, I'll just order a normal wrist rest with no bottom panel. :)
« Reply #227 on: Fri, 21 August 2015, 06:12:57 »
I understand the negative slope, but not sure what type of piece you are wanting (simple piece or piece with bottom plate?). Approximately how tall would the front of the rest be? And how tall for the back (where it touches the keyboard?
Offline shrubkeys
« Reply #228 on: Fri, 21 August 2015, 13:13:40 »
The front of the wrist rest would be roughly the same height. Currently, the bottom plate extends out as a flat piece of wood, i.e. a rectangular cross-section. I was suggesting that the bottom plate be glued, planed or cut to a trapezoidal cross-section, so that a keyboard sitting on it would tilt back. Or am I misunderstanding what you mean by front/back? I thought this was simple, but if it's not - or if I'm not making sense - I can sketch something out when I have a second this weekend.
« Reply #229 on: Fri, 21 August 2015, 14:03:43 »
I see what you are saying now. I have no way of cutting a piece of wood like that.
Sorry
