Author Topic: Remove Key Surround From Filco ?  (Read 1146 times)
Offline Dirty Bint
« on: Sat, 14 June 2014, 07:52:41 »
Hi,
Can anyone please tell me how I separate the top and bottom casing parts on a Filco standard size keyboard?
I have removed the underside three screws including the one beneath the "Do Not Remove" sticker but cannot separate the top from the bottom of the keyboard. It seems to be stuck on the lower edge (space bar edge)
Are there more screws concealed by  the underside rubber feet strips?
Thx
« Last Edit: Sat, 14 June 2014, 07:59:22 by Dirty Bint »
I\'m so filthy, I\'m disgusting.
Offline FrostyToast
  • Litshoard
Re: Remove Key Surround From Filco ?
« Reply #1 on: Sat, 14 June 2014, 08:05:17 »
IIRC there should be some plastic tabs on the sides which hold the casing together.
Anyhow, if you just look up how to remove a filco housing/case you should get what you need.
Quote from: elton5354
« Reply #2 on: Sat, 14 June 2014, 08:15:55 »
