Author Topic: NEC Mechanical Keyboard  (Read 3773 times)
« on: Sat, 14 June 2014, 13:03:50 »
It should come with blue NEC switches as seen here
http://www.ebay.com/itm/181193301028
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
Re: NEC Mechanical Keyboard
« Reply #1 on: Sat, 14 June 2014, 15:51:11 »
i have the 412 with the same switches and i am pretty fond of it.
this one could use a retrobrite bath, but nothing difficult to turn it around
i believe the 410 and 412 both have ds?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
« Reply #2 on: Sat, 14 June 2014, 15:58:14 »
It should be double shot based on the model number and pics I've seen.  It's supposed to be a nice, light switch.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #3 on: Sat, 14 June 2014, 16:33:33 »
kind of sounds like a blue, but feels softer for sure :D
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #4 on: Sat, 14 June 2014, 16:35:41 »
sorry...............trying to figure out how to embed this video :-\
modedit: you use the youtube tags and must remove the s so it's just http
Code: [Select]
[youtube]http://www.youtube.com/watch?v=guzOG8njkUw[/youtube]
« Last Edit: Sat, 14 June 2014, 17:08:07 by IvanIvanovich »
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #5 on: Sat, 14 June 2014, 17:19:09 »
thanks!!
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #6 on: Sat, 14 June 2014, 17:59:03 »
nec 410....basically the same thing
still trying to figure it out..........did what you said...........butttttt
« Last Edit: Sat, 14 June 2014, 18:07:20 by terrpn »
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #7 on: Sat, 14 June 2014, 18:14:54 »
« Reply #8 on: Sat, 14 June 2014, 20:09:50 »
I have an NEC APC-H4100E - which I gather is very similar.
The most interesting part is that the switches actuate BEFORE the click, so with a little care it is possible to type almost silently on this.
Fantastic board - I learned many of my programming skills on a similar board many years ago.
