Author Topic: PBT Dye- sublimation Black on Black keycaps  (Read 1733 times)
Offline Blobsey
« on: Sat, 14 June 2014, 21:40:03 »
I've been looking for some new keycaps for my CM storm quickfire XT and I stumbled upon these on mechanicalkeyboards.com
They're here: http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=287
I'm not too familiar with how keycaps are restocked, as these have been Out of Stock for a long time. Are they a limited edition sort of thing, and am I out of luck? Is there any other place where I could find these particular keycaps?
Offline ideus
  • Björkö.
Re: PBT Dye- sublimation Black on Black keycaps
« Reply #1 on: Sat, 14 June 2014, 22:45:53 »
Have you contacted the vendor directly? It should be the best way to go. A GB for a similar keyset has just ran by Ivan recently, however the price was higher than the set you referenced. You may also post in the vendor's thread here at GH:
http://geekhack.org/index.php?board=100.0
« Last Edit: Sat, 14 June 2014, 22:54:20 by ideus »
