Author Topic: MechanicalKeyboards.com Question  (Read 1947 times)
Offline Blobsey
« on: Sun, 15 June 2014, 23:12:12 »
I made a topic earlier about wanting to buy some keycaps, and I found a set that is very similar on mechanicalkeyboards.com.
This: http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=69
Although it says "Out of Stock", the "Add to cart" button is still there. On other "out of stock" products, however, the "add to cart" button is absent. Is this a common occurence? I tried contacting them but I didn't get an answer.
Offline exitfire401
  • The Force is Re/\l
Re: MechanicalKeyboards.com Question
« Reply #1 on: Sun, 15 June 2014, 23:26:10 »
They have a vendor forum here. I would suggest contacting them there, or by e-mail.
Offline Blobsey
« Reply #2 on: Sun, 15 June 2014, 23:44:09 »
Ah sorry, I didn't know that. Thanks.
Offline exitfire401
« Reply #3 on: Sun, 15 June 2014, 23:45:32 »
Not a problem! Just letting you know. They're fairly active in their subforum, so I figured you'd receive help there quicker than posting here.
Offline umeboshi
« Reply #4 on: Mon, 16 June 2014, 01:12:01 »
I saw that before for a keyboard that I wanted to buy there.  I went ahead and added it and paid for it, but I got refunded the next day.
In short, I think it's really out of stock when it says out of stock...
Offline Blobsey
« Reply #5 on: Mon, 16 June 2014, 07:55:43 »
Alright. I ended up not ordering it after all. Thanks for the replies, you probably just saved me some headache.
