Author Topic: How do I make this space bar fit a Ducky Shine 3?  (Read 2538 times)
Offline Kayla
  • :3
« on: Mon, 16 June 2014, 02:43:42 »
The space bar does not fit on a ducky g2 pro. Was curious why and how I can fix it?
(Image used is not mine. I rehosted on puush for posterity.)
Offline infiniti
  • I <3 KB
  • Bob was here
Re: How do I make this space bar fit a Ducky Shine 3?
« Reply #1 on: Mon, 16 June 2014, 03:31:33 »
See the white inserts in the stems?  Those are for use with costar stabilizers.  You need to remove them so that they will work on the Ducky which uses cherry stabilizers.
P.S. the subject mentions Shine 3 but the post mentions G2 Pro.  Anyway, both use cherry stabilizers.
Offline Kayla
  • :3
« Reply #2 on: Mon, 16 June 2014, 03:48:30 »
I have a shine 3 my friend has a g2pro and he tried them on the g2pro without the costar hooks. Il get pictures.
Left doesnt fit. Right fits. Do I have to cut the stems?
Offline BlueBär
« Reply #3 on: Mon, 16 June 2014, 04:57:07 »
Looks like your spacebar is slightly bent, is that correct?
If so that is probably the cause why it doesn't fit, Costar stabilizers usually have less problems with that. You can use a hairdryer and try to bend it straight.
Offline Kayla
  • :3
« Reply #4 on: Mon, 16 June 2014, 05:00:27 »
Hair dryer on POM? I wonder if thats a good idea.
Offline BlueBär
« Reply #5 on: Mon, 16 June 2014, 05:22:27 »
As long as you're careful and don't overdo it you should be fine.
Offline Kayla
  • :3
« Reply #6 on: Mon, 16 June 2014, 05:31:22 »
If anyone else has info about the jelly set having a space bar that doesnt fit universal let me know ~
Offline BlueBär
« Reply #7 on: Mon, 16 June 2014, 05:52:43 »
As you can see the stems are in the correct position but just slightly off. This is due to it not being straight. This happens on ABS  and PBT, too. As you can see here:
http://geekhack.org/index.php?topic=54498.0
http://geekhack.org/index.php?topic=35153.0
I'm not the only one who recommends the hairdryer method. Another method that gets recommended there is warm water.
Offline Kayla
  • :3
« Reply #8 on: Mon, 16 June 2014, 06:17:42 »
Im scared to use a hair dryer because my girlfriend dryed her caps with a hair dryer and they melted.
Offline BlueBär
« Reply #9 on: Mon, 16 June 2014, 06:41:14 »
Set it to a low temperature and use it gently, just warm up the spacebar slightly, check if you can bend it and if not warm it again. Small steps and patience is the key here.
