Author Topic: Looking for new keyboard (recommendations)  (Read 1228 times)
Offline yuukou
« on: Mon, 16 June 2014, 15:52:12 »
Does anyone have any recommendations for a keyboard that is white with mx browns and is tenkeyless?
Re: Looking for new keyboard (recommendations)
« Reply #1 on: Mon, 16 June 2014, 22:47:20 »
KeyCool?  if you can still get them.
Filco TKL is off-white (if you can still get it).
Ducky has a white model, but I have only seen full size.
Offline BlueBär
« Reply #2 on: Tue, 17 June 2014, 05:41:49 »
HendyZone sells Leopold keyboards and they're available in white too, however it looks like he has run out of stock of MX Brown boards.
Offline Oobly
« Reply #3 on: Tue, 17 June 2014, 07:32:36 »
Does it have to be exactly TKL format?
White Poker 2 with Browns: http://www.banggood.com/KBC-Poker-2-Mini-61-Keys-Mechanical-Gaming-Keyboard-Cherry-MX-Brown-p-909746.html
Technically it is tenkeyless since it doesn't have the tenkey area....
Noppoo Choc Mid is a white TKL with MX switches (red switch version: http://www.amazon.com/gp/product/B00EDEW3IG/ref=s9_simh_gw_p229_d0_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=0RJXB8WADPBXYVATCYX4&pf_rd_t=101&pf_rd_p=1688200382&pf_rd_i=507846), not sure how hard it is to find one with Browns.
Choc Mini is an 84 key compact and also has a white version.
Otherwise you may be able to find a white Keycool 87 with Browns somewhere. There's also the Filco white Majestouch 2 (slightly off-white) and the Filco white carbon case. Not cheap or all that easy to find, though.
Ducky Shine 3 white edition and year of the rabbit are fullsize only. I've seen some white Rosewill boards, but I think they're also only fullsize.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Razor Lotus
« Reply #4 on: Tue, 17 June 2014, 13:33:00 »
giving a budget would be helpful.
<$100?
$100-$150?
$150-$200?
>$200?
Of course, break it down into smaller categories if you need to
Offline yuukou
« Reply #5 on: Wed, 18 June 2014, 15:42:08 »
My budget is probably around 200 max. I have a filco TKL but it is up at my school apartment, so I just need something to use at home because my noppoo is dying (after 3 years-ish). I am fine with boards that are smaller than a regular TKL as well. For example, I have been looking at the Leopold FC660M also.
« Last Edit: Wed, 18 June 2014, 15:44:14 by yuukou »
